Whats your take on running a ALUMINUM RADIATOR in a 66 f250 4x4! The top tank on my 66 split today! then its 500$ to have it reworked + 50 miles to the shop!
Found this with a LifeTime Warranty
http://www.ebay.com/itm/290677868807?ss ... 1423.l2649
RADIATOR ?S
RADIATOR ?S
1971 Ford F350 DRW, 1971 F100, 1966 F250 4x4, 1966 Galaxie,
1962 IH R-185 Firetruck, 1960 F750 FireTruck, 1960 Gmc 6000 Firetruck
1959 Ford Custom, 1940 Ford Truck
Re: RADIATOR ?S
Unless you are going for origanality by all means order the radiator.
- banjopicker66
Re: RADIATOR ?S
My radiator is for a 1970's 460. Bolted up perfect, and cools mighty fine.
Check my gallery for pictures and comparisons of the old brass one with the new aluminum one side by side.
Re: RADIATOR ?S
banjopicker66 wrote:My radiator is for a 1970's 460. Bolted up perfect, and cools mighty fine.
IS your tanks aluminum? The one im looking at is 100% aluminum all TigWelded.
- banjopicker66
Re: RADIATOR ?S
No, I went the cheapest route. It has an aluminum core with plastic tanks.
Re: RADIATOR ?S
I have 66 F100 2wd core support , I have a 1976 460 going in the truck and this radiator measurements are the same. When I typed in 66 352 the same radiator part # came up for both the 76 460 and the 66 352. I will order it tomorrow and post how well it fits.
1966 Ford F100 SWB
1966 Ford F100 Camper 4 x 4
2009 Ford F150 4x4
2009 Ford F150 4x4
Re: RADIATOR ?S
Is the hood clearance for the radiator on a 66 different than a 64?
Just wondering if the taller tanks would work in a 64.
Also, did you get the new radiator installed?
J
J
1964 F100, 292ci
1963 Buick Wildcat, 401ci
They just don't make them like they used to.
Re: RADIATOR ?S
Hood should be the same for a 64 , not installed yet. I ordered it from O'Reilly's $239 plus tax and it's gloss black powder coated. It looks awesome !
Here's the link
http://www.oreillyauto.com/site/c/detai ... d=radiator
I just called the store and ordered it , if it doesn't work for some odd reason , you can return it to O'Reilly's
Here's the link
1966 Ford F100 SWB
2009 Ford F150 4x4
2009 Ford F150 4x4
