Sorry if this has been discussed before.
Just finished installing all new brake lines, wheel cylinders, shoes, converted the system to power disc/drum with a new proportion/distribution valve. The problem is I have a very soft pedal when the truck is off and no pedal when the truck is running. That leads me to believe that the booster is good but something else is wrong. I have bled the lines by cracking loose the right rear bleeder valve and letting it drain for about an hour then going from corner to corner bleeding the lines.
What could it be?
What's wrong with my brakes?
Family First!
tomrooster
Re: What's wrong with my brakes?
Did you bench bleed the master cyl. before installing it. Might be the problem. Tom
Here's one
http://autorepair.about.com/od/fixityou ... -bleed.htm
Here's one
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
- BigWindowFord
That's what I think too. I changed a master cylinder on an O/T car and ignored the bench bleeding. Same symptoms. The air will eventually either go out to the reservoir or arrive at a bleeder screw but on the O/T car it took thousands of miles.
Notice how I do not care driving around on crappy brakes - pathetic really
- banjopicker66
x3 on the bench bleeding.
No, didn't bench bleed. I will give it a try and see what happens.
Thanks!
Thanks!
Family First!
Now I'm stumped
I've taken the MC off and bled it. Reinstalled it and bled the brakes but still have no pedal to speak of. Checked to see if the rod was long enough to engage it and it is. I know the booster is working fine so could it be the MC is bad?
Family First!
Feeling a little better now that I have some pedal. Found that the shaft coming out of the booster into the MC was adjustable (
forgive my ignorance) with a small bolt threaded into the end of the shaft. Adjusted it all the way out and think I still need more as I don't have very much pressure. What do you guys think?
Family First!
Worked it out. Added a longer bolt to the end of the shaft out of the booster. Stops on a dime and gives nine cents change!
Family First!
You should adjust that rod to give about 0.010" clearance, if you want a dimension. But if it works and the brakes don't drag, you got it right. Too long can be a problem also.
yes, some clearance is needed as brakes build up heat and will stick.TXSlick wrote:You should adjust that rod to give about 0.010" clearance, if you want a dimension. But if it works and the brakes don't drag, you got it right. Too long can be a problem also.
school of hard knocks, lesson 127.
