The 66 is back home
66camperspecial
The 66 is back home
After getting it painted in november I parked it in a garage I rent for the paint to dry while I got my 2wd bronco finished and its finished so the 66 is back home and I am starting on it.
66camperspecial
Re: The 66 is back home
Before I can do much to it I need to get the lawn mowers ready since we did not have a real winter so I think we will be cutting grass early,I am doing a motor swap on one of my lawn tractors and should have it finished this weekend so from then on it will be working on the 66.
2WD Bronco?....and it's not a Bronco II ?? Tell me more!!:)
James
James
66camperspecial
I took a 1988 full size bronco and converted it to a 2wd,ever since I seen the 2wd lightning bronco prototype back in the mid 90s I wanted a 2wd bronco and since they were never made I built my own. Just unbolt the front differential and bolt on 2wd parts and that part is done,I removed the 4x4 trans and transfer case and installed a 2wd AOD and had a Lincoln town car drive shaft cut down. I had Eaton Detroit spring make me a pair of lowered rear springs and found a set of lightning front springs.
66camperspecial
Here is a picture of it now,the springs are going to be installed next week and aligned.
- 011.JPG (240.21 KiB) Viewed 1544 times
66camperspecial
I was looking over the paint today and do not like my body work I had done on the drivers side of the bed so its going to be reshot next winter,I was in a hurry to get it painted before it got cold and could have done a better job of sanding on the bed sides. I am going to put it back togather and drive it this summer but I will have to redo the bed side on the drivers side.
66camperspecial
Got the aluminum grille in tonight and I need to find a chrome bumper for the front now as a painted wont do.
66camperspecial
66camperspecial
- Alan Mclennan
Nice colour!
Ah Yes,
know the colour (color) , downunder known as ....paddy wagon blue.... walloper's dogbox blue...
very popular with the lads .
Is it medium blue / marlin blue ?
cheers
John
cheers
John
Lost in the Mountains Blue Mist ......
66camperspecial
I got the door glass and wings back in,I bought a shop manual but did not look at it and figured it out. Its been 3 years since I took them apart and it took awhile to figure out the way it went back togather,the first door I put everything togather in the wrong order but the other door went much easier.
66camperspecial
For those who are interested in the bronco the lowered springs have been installed and picking it up tomorrow morning and will post pics,its still a little higher then I like but looks good and hope the springs settle some.
Nice door gaps!
- Julian Mule
Looking good!
