For Computer Geeks
ripsnorter
For Computer Geeks
Post by ripsnorter »
Non-Computer Geeks, just skip down to the last line :P
Having a lot of fun this evening.
A friend of mine has had an old Pentium II in his basement with a good 17" monitor that he hasnt had a use for in quite a while. I told him I could use it rather than him throwing it away. Finally got around to setting it up somewhat tonight, and its a blast :D
Its a full tower machine, with a 400mhz CPU and a 6GB Hard drive in it. Sounds slow, but I've got in mind to buy a $20 PCI SATA controller card, stick all of my Hard drives in there and make it a 1+ Terabyte Network storage. This will give me a central point to store all of my files when oinklette and I want to cuddle in the back room and watch "Its a wonderful life" on her laptop. Plus I'll then have free Hard Drive slots in my main box for another couple 500GB drives. I'm probably going to install FreeNAS (a network storage version of FreeBSD that needs only 32MBs installed to run, and has a good software RAID built in)
This has also given me a chance to do my very first install of Linux. I've always wanted to play around with it, but never had a free machine I could use, since I need windows for a great many things on my main box. I installed Ubuntu 6.06 on it today, and been playing around with it off and on. Not bad at all, in fact fairly similar to windows actually. Ubuntu does have a reputation for being the most "windows friendly" of the distros though. I havent delved too deeply into it however, since the CPU seems a bit choked trying to run it. I wouldnt mind playing around with some of the other, less windows-ish distros. FreeNAS should run fine however.
The other fun thing I've done, is hook up the 17" monitor as a secondary on my main box. I've only been using it for an hour or so, but I already can't believe I lived without it. I've wanted to do this for years, but never could justify buying a second monitor. Its amazing how much easier it makes it having a second monitor to drag windows to. It allows me to watch various shows, video clips etc while I'm doing web browsing, running forums, and even gaming. I dont have to shuffle windows around anymore, and managing files is much easier as well.
Having a lot of fun exploring the options with this setup, and best of all it was a free setup I rescued from the trash :)
For all non computer geeks... I get to play with a second computer to store lots and lots of pictures of slicks on, and I also have a second monitor so I can look at 2 pictures at once :P
fmartin_gila
Post by fmartin_gila »
Ripsnorter,
Please keep us informed on this. I sent for and recieved the 6.06 version and then found out they were going to release 7.04 so I just held onto the early one and asked for and got 7.04 when they did release it. I haven't installed either yet, being somewhat leery of all things electronic.
Fred
ripsnorter
I went with 6.06 because the computer I was going to run it on is so underpowered in the CPU department.
My understanding is that 6.06 is the more stable of the two and that 7.04 is the one with more eye candy and new features. Since my CPU was only 400mhz (384mb of RAM) I didnt think I'd need all the eye candy. 6.06 also has a longer support life according to the main website, I wouldnt be too worried about that however as there are usually endless IRC channels and forums for support.
If you want to know more about it in laymans terms, I'd suggest HardOCP's 30 Days with Linux article.
MadMaxetc
Post by MadMaxetc »
I tried to do the same thing with a 300mz PII as well. I found that the RAM limits of the Motherboard caused the access times to the HD to be way to slow. I think that the SATA card would ba a waist on that slow a machine. I would stick with IDE. Plus, I don't know if the SATA card will even WORK in that old a box.
Mother boards and chipsets are cheep ($100 - $150). You could get one and then do the SATA no problem.
I go on www.NewEgg.com all the time, if I only had the $$$. :D
My Build Thread
Bills 66
Post by Bills 66 »
I am running ubuntu 7.04 on a 2,4 gig machine and like it so much I forgot about windows. Also have it dual booted on my laptop. Was a breeze to install for a non linux person. My understanding is that it is meant for newer machines and other linux distros are better on the older rigs.
ripsnorter
the only reason i'd run a PCI Sata controller is SATA is hot-swappable. And for my needs that might be a big plus. I might possibly go IDE though, but I want some more big SATA drives for my main box and i dont have any free connections.
as long as the controller card is PCI interface, it should work on the older box.
Ford4jack
Post by Ford4jack »
Ok I will fess up read the whole thing understood the last line
Sounds like y'all got it going on though.
banjopicker66
Post by banjopicker66 »
I just finished installing Red Hat 5.0 Enterprise on a monster 4 processor 10 gig RAM server at work. Easy to install, and I made the SATA raid with Disk Druid during the install.
It has 20 terabytes of storage. This is a 25K user community, though.
ripsnorter
I'm only using it for personal network file storage, so even a 400mhz should be plenty for it.
If I were doing a website server it would be a whole nother story.
It'd be fun to build a big rig like that banjo, especially to play around with it :)
(drools at the thought of 20TB) :D :D
Glad the last line made sense to everyone :)
kid2
Post by kid2 »
My VCR still blinks 12:00
65 f-100, Mostly Stock
64 F-100, 4in roof chop and on a car frame
64 F100, Project, not sure what to do with it
61 Long Uni project
79 F-250 Super Cab Long Box
74 Duster, Future Project
Dropped,Chopped,Tubbed,and Stubbed is the way to go
It is easier to ask Forgivness than to ask Permission
castruck_1964
Post by castruck_1964 »
I can set the clock on my VCR :D
When it comes to confusers I can turn it on send an E-mail find the ODD web site :shock: and can barely navigate around this Site :shock:
All the computer stuff you guys were talking about made as much sense to me as a French Speaking Canadian :? :roll: :wink:
Slicks rule
dd/ 19 F150,97 Tbird
62 swb bbw uni next project
460 C6
Ken
DocDave
Post by DocDave »
My son runs linux in a virtual machine on his xp based laptop
says it worked so well he's added a couple of other os's running in virtuals. If he has a problem he just deletes the virtual machine and starts again.
I had a P1 75 that I kept running for 10 years. It was soooo overclocked and running stuff it was never intended to run. I still miss Kermit the computor (paid big bucks back then)
When I first got into computers we had 16k memory and used to solder extra chips on top of the dram chips to increase to 32k
Now my password list takes more room then 32k
Dave
