Carb Question
64F100StepSide
Carb Question
I have a 64 223 manual. My 1 bbl carb is the 1101 Autolite. On the top front, there is a rod that is connected to an arm on the side of the bowl. I just bought a rebuilt carb from AutoZone and that rod has been removed and the hole in goes into is plugged. The picture on their website SHOWS the rod. Is that rod needed? This is NOT the automatic carb that shows rocker arms on both sides of the bowl. If needed, I need to take it back and ask for the exact carb that is shown. thanks. Craig
Craig
- Brians1966
Re: Carb Question
Craig
That is what they called the vent rod on the 1100 series Autolites, most re-manufacturers eliminated the rod and cap the vent hole.
I didn't get my carb from Autozone but I got the same set up on my 66 and have not had any issues at all.
Brian
Brian
1966 F-100 LONG BED, 240cid 3 speed red and white, Red and White Interior with a Mossy Oak Seat Cover
2013 Ford F150 STX Supercab 5.0 litre
DETERMINATION: The feeling you get right before you try to do something incredibly stupid!
CONFIDENCE: Is the feeling you have before you fully understand the situation!
