so far so good
*motor*mount*
so far so good
every thing i did to my 64 to improve it has worked better than i thought it would. the motor is rebuilt stock except for the elctronic igniton and the clifford intake and split header and the hollye 2bbl. and the bigger less restrictive air cleaner. the mouse is a big dawg now.you wouldnt beleave the truck has a 223. it dont even ride like it used to, thanks to the wider tires on all 4 corners. the whole truck has been rewired and has a gm type fuse box mounted under the dash on the fire wall. above the head light dimmer switch. and thanks to the new after market raidator and flex fan ment for a chevy suburban but it fit it dosent get over 175 degrees. some might say that too cool, if it got any hotter the oil would get thinner and it wouldnt run a 41 psi. if you can still see my photobucket pictures you will see my cooling system and intake and headers. the exsaust pipe is 2.5 inch with 2 2 chainber flow master muffelrs
Jim H. Shiflet jr. my pictures are at photo bucket shifletjr is the name on the album. Click this link to see my pictures http://m815.photobucket.com/profile/shifletjr .also look at newest uploads and mobile uploads. 1964 costume cab and 2 ford f650 flat bed wreckers. and now a 2008 chrysler convertible
