Steering Wheels
bmcgc
Steering Wheels
Post by bmcgc »
My turn signal cam is broke, my horn index is broken, my steering wheel and horn ring look like crap.
The 75 p/s column Im going to use isnt any better.
I really want to figure out if a 66 Mustang steering wheel will work. I can buy a red repop for $115. No sanding, no filling, no painting.
The various boards say that the turn signal cams are different and it will not work.
What if I used the correct year Mustang turn signal cam that goes with the Mustang Wheel?
Im no rocket scientist, someone must have had this idea and made it work.
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
1998 1100 Aero (Hers)
2001 1100 Aero (Mine)
Wish List:
Win Indy 500
Ask Elvis WTH he has been
Re: Steering Wheels
I have not tried this, but do have a 67 rustang in the garage that I could take a look at. It would be interesting to measure the mustang column to see if you could do a complete replacement. You'd have to use the correct dash bracket, but it might move the wheel away as well.
Hawkrod
Re: Steering Wheels
Post by Hawkrod »
Yes, any 67 and older Mustang steering wheel physically fits a stock Slick steering column. There are different turn canceler situations depending on years but it can all be worked out easily. In 68 the Mustang steering column got larger in diameter. The wheel will still bolt on a slick but looks odd. Hawkrod
qwertyd10n
Re: Steering Wheels
Post by qwertyd10n »
I believe the Mustang steering wheels have more dish than the truck steering wheels... make sure to consider that before buying.
Cheers,
Dion
The Big M
Re: Steering Wheels
Post by The Big M »
I have a selection of NOS turn signal cams from Shee-Mar, several styles of which are listed as fitting 61-66 trucks, even though each is slightly different:
But according to their application chart 61- 64 2WD truck, 65-66 2WD truck and 66 Mustang all use the same cam, SM-9. As do 67-72 and 73-77 trucks. See pages 14 and 15:
http://www.shee-mar.com/PDF/2011%20catalog.pdf
64 f100
Re: Steering Wheels
Post by 64 f100 »
I need one also, and this is not one fits all situation. I believe I need the 14 but not positive on that. The Carpenter switch is made like the later Ford truck switches with two wires connecting to the cam canceler.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
