Bought a truck to tow my trailer with
Well I have been looking for something to tow my trailer with since I traded my 90 F-150 for the 61 long UNi last month. I bought a 79 Super Cab F-250 with a 460 and Auto trans. The interior is almost perfect but the body has some issues. THe rust isnt as bad as I thought when I first looked at it. The guy wanted $2500 and I passed on it but I noticed a Yesterday that he had it posted for $1200 so I called him. He said he had some problems with it dieng and not restarting, He thought it was the fuel pump or vapor locking and that is why he dropped the price. He met me at my Office and when I went out to test drive it it would not start but I bought it anyway. I went back later and it fired right up. I got about 5 miles from home and it quit and would not restart. I checked and ruled out the fuel pump and vapor locking. My neighbor come to pull me home and I used some Ice from his cooler to cool the coil down and started to drag it home. We got about 2 miles and all the cool evening air going under the hood finished cooling the coil and it fired up so we unhooked it and I drove it the rest of the way home. I know the problem is a weak ignition coil and when it gets hot it will not provide any juice for spark. I will go get a new coil tomorrow and drive it till it quits on me again and will change the coil and I am sure that will fix the problem. I think it was a pretty good deal cause he dropped the price because of the problem with the engine dieing and not restarting till it cools down. I am going to use it for towing and not much else so it turned out to be a pretty good deal.................Kid
65 f-100, Mostly Stock
64 F-100, 4in roof chop and on a car frame
64 F100, Project, not sure what to do with it
61 Long Uni project
79 F-250 Super Cab Long Box
74 Duster, Future Project
Dropped,Chopped,Tubbed,and Stubbed is the way to go
It is easier to ask Forgivness than to ask Permission
61 Long Uni project
- Johnny Canuck
- banjopicker66
- FORDBOYpete
Also great advice from Banjopicker & an earlier timing set with a 0* TDC, not a -4* TDC like yours .
After the Cloyes Double Row Accu Roll roller timing set for 1968 thru 1972 385 engine,
Spring for double platnum tip Autolite Plugs (both electrode & ground are platnum) plus a set of
Motorcraft Ignition wires, a cap & rotor.
FBp
Change is the Only Constant
Good deal Darrell, I vote for the Duraspark box too. Bout a 10 minute $25 fix.
Darrell emailed me pics of the truck, it's pretty nice.
Well, by all means don't post 'em here so the rest of us can see.Greg D wrote:
Sorry about not posting pics but I don't know how, LOL. I bought the coil and brain box today and am going to go for a drive and when it quits I will change the parts to make sure I found the problem. The engine only has about 20,000 miles on it since a rebuild by a reputable shop. I am sure the guy who bought it could not figure out why it kept quitting on him and decided to selll it and that is why he dropped the price cause it was getting worse. The truck has all new brakes, brake lines, and master cyl and the interior has been redone recently. i will see if I can figure out how to put some pics up.............Kid
61 Long Uni project
61 Long Uni project
shawns fords
as long as you have a spare brain box (duraspark) behind the seat the one hooked up wont ever fail but the day you take your spare out, it is guaranteed to give up on ya
ive kept a spare in my 78 for years now, ever since the other one went out in it, havent needed it again
oh cool deal on the 1200 bucks for a f250
- 6166 Junkyard Dog
man I just brought in a F-250 super cab out of AZ. That is a 100% rust free that needs nothing as far as body work, alum. intake. hooker headers that would make a great pull trailer interior is ok
Kathy
Now Cooper will try his best
HELP, Ok guys the coil and ignition box was not the problem. I ran it till it quit and changed the box and coil and it did not start. Any body have any suggestions what to check next.
Tom, What you want for the one you got from AZ.............Kid
61 Long Uni project
61 Long Uni project
- Rustbucket
- Johnny Canuck
I those 2 things aren't it, kid, i think you must be vapor locking. Got a thick carb spacer handy?
Your Money back guarantee check is in the mail
- 6166 Junkyard Dog
kid2 I PM You a message with also what should be wrong & for any else the module inside the dist. is getting hot and breaking down , you can by the modules inside the dist. separate we did one one a 351/400 motor
Kathy
You might wanna check the wire harness leading from the distributor & coil to the ignition box. My '84 Mustang had similar running problems shortly after I got it.
I discovered sorta by accident that all the insulation on those wires had hardened up & was actually falling off
leaving bare wires to short across between themselves. That car had all sorts of funky running problems.
I rewired that whole harness & that fixed it. I later found out that it's sort of a common problem with some years of Fords.
Well I think I found something. I have been looking at a black tarry substance on the in side of the inner fender. I got to following the trail up and it looks like it came from the ignition box mounted on the fender. Is there anything inside the box to get hot and run out that would look like tar.. I am assuming it is the ignition box and the reason it did not solve the problem when I swapped them out was that I did not mount it to ground it and just layed it inside the fender and hooked up the wires without bolting it down to make a good ground. I will check everything else you guys have posted here and PM'd me to check. Thanks everyone for all your help................Kid
61 Long Uni project
61 Long Uni project
Well if I would pull my head out of my butt before I start to work on stuff it would go much smoother. I changed the coil and ignition box and that was not the problem. Got a Chiltons manuel and checked the stator coil inside the dizzy with a ohm meter and that was the problem. I changed it out tonite with the help of my Neighbor and it runs great now. I spent $52 on unneeded parts and $21 on the right part but I got extra coil and brain box under the seat now. Thanks for all the help guys, you rock as usual with advice..............Kid
61 Long Uni project
61 Long Uni project
