Radiator help
1965 stepside
Radiator help
Post by 1965 stepside »
Well if the picture uploaded the first is of the rad I have taken our
And the second is what I picked up yesterday,I pull it out of a f350 1978
Mine is a 1965 it looks like it will fit with a little fabrication if any one
Has experience dealing with puting in a radiator do you have any advice
Will this work or is it to big
Re: Radiator help
Pics didn't come through, but the PO put what he described as a '78 F250 radiator in one of mine. It's a rather large setup cooling a 460, so it appears it can be done easily.
1965 stepside
Re: Radiator help
Ok so just gona have to make some adjustments
So it will fit. I only have a 302 is this gona be ok
Or would it be to big
Re: Radiator help
As long as you have a working thermostat, aside from slight additional weight and cost of coolant, I see no problem; it's one of those "big is better" situations IMO.
1965 stepside
Re: Radiator help
Sweet guess I get to learn some fabrication
