Power brake help!!
marcfridge
Power brake help!!
Post by marcfridge »
I did a 4 wheel disk swap on my 62 effie. It is a Performance Online kit which uses a GM power booster. My brake pedal is hard as a rock and I have to fight to get the truck to stop. I added a vacuum canister, but it didn't help. I am running a 460 with Edelbrock performer carb, intake and cam with a C-6 auto. I assume its a vacuum issue, but I'm lost at this point. Any insight out there?
Re: Power brake help!!
You need to verify the check valve is centered it may be blocking either the front or rear systems.
Hunter's 64
Post by Hunter's 64 »
was / is the porportioning vale set up for 4 wheel disk , or could it be a front disk rear drum ? :2cents:
Danny
marcfridge
Its supposed to be a four wheel disc valve. I'll have to check on it. thanks guys. I'd like to post pictures, but I still haven't figured it out.
