Bed Floor Replacement
62bigwindow
Post by 62bigwindow »
The bed floor on my Uni is in need of replacement.I was wondering what my options are.What have you guys used?I was thinking of using sheet metal but not real crazy about that.Is there a repop bed floor that is close to original?
ken_b
Re: Bed Floor Replacement
Post by ken_b »
This is on my list too. My bed floor isn't all that bad, but straighter would be nice.
JOSHF100
Post by JOSHF100 »
I'm in the same boat , so to speak.
I'm planning on cutting one out from a newer truck and grafting it in.
LM14
Post by LM14 »
When I had the rusty '61 uni, I had a friend in the body shop business show me a couple different bed floors to use. There are some Dodge floors that have no holes in them for attachment bolts, they attach from below so you can put the bolt holes anywhere you want. Some newer Ford bed floors are also fairly close. His suggestion was to spend a couple hours in a junk yard deciding what style I wanted and get the year then he could order me a new floor pan from his suppliers. Use the main ribbed section for the center area and re-make the outer 4 corner pieces from sheetmetal and a little time with a sheetmetal brake.
My newest '62 has decent floors so I never followed up to find that "magic" year for a donor.
jwh f-100
Post by jwh f-100 »
I used a floor from a 86 f150.. the box side were smashed so I got the donor bed for free..
Pics in my build thread..
viewtopic.php?f=32&t=8950&start=20
Jason
Beer will change the world.
I don't know how but it will.
Anthony
Post by Anthony »
I used a mid 90's center floor I think.. :hm: I left the supports attached to the new floor and notched them to the right height then welded in and wala!! instant new floor... mine is not the straightest but for the $10 I spent, I can live with it...
Image the under side notched...
Image the top side welded in...
dmsmith6
Post by dmsmith6 »
I used 1/8th inch plate. Not original but so far holds up well.
Limestone66
Post by Limestone66 »
I was thinking about adding a bed-over type of deal using 3/16Th steel diamond plate on my truck. This can be ordered cut to fit on the four corners and a 4x8 sheet as the center, tack it all in and paint it.
Long live the 352
........Ron..........
1966 Ford F250 Custom Cab {Longbox}
1996 Toyota Camry {Wifes ride}
1940 Harley Davidson knucklehead {Retired in 2006, gave to one of my sons in 2010}
1975 Harley Davidson XLH {Groundpounder}
2005 Harley Davidson Deluxe {Nostalgia} Almost home 'girl'
In memory of Donald G. Roswell- My freind and 'brother'.
