Time for a new Starter
so I've gotten to the point where i need to replace my starter. (I got tired of doing the old push start. Anyway, I went and bought a new starter (pretty cheap) and when i looked at it, there was just a big rod sticking out of it. And thats when i realized i might have just gotten in over my head
Now im about to go pull my old starter. And the guy at the stor said i have to take something off it and put it on my new one, and its a difficult thing to do
So anyone think they can give me a play-by-play?? Please
I guess once i get the old unit out of the truck ill know a little more of what im dealing with
Thanks ahead of time
-Dave
-Dave
- Uncle Skip
heres a pic of the 2 starters (old and new)
heres a close up of the gear teeth slightly pulled apart
and here is another close up with the teeth together
i think the problem might be that the teeth have been rounded off, cause the starter to "miss" Since the actually starter was so cheap $25, i might as well keep the new one and use it.
As far as the rest goes, I'm not sure what to do. I'm thinking about going on ahead and replacing the bendix cause im not sure its worth going through the hassel of trying to get it off and put it on the new one. It might be worth it to just replace it as well
thanks
-Dave
thanks
-Dave
That piece is your starter drive, or "Bendix" & it looks broken. The drive is supposed to be retracted when it's sitting still. The position it's in now, it would be engaging the flywheel to start the engine.
If I recall, it's held onto the shaft with a roll pin, although I could be wrong.
- YukonCor55
Swimholm,
Just for reference for those of us with trusty old 292s...where did you get the starter and Bendix? Part numbers??
Thanks,
AJ
Thanks,
AJ
SMSgt USAF Retired
- YukonCor55
Much Appreciated Sir!!
SMSgt USAF Retired
fmartin_gila
just an update, the bendix the parts store guys order was for the wrong type of starter. so after looking through some books with them we found the right one, bad news it cost about $60
i think the part number for the starter is ULT 03-0214
let me know if thats right or not, its the number on the side of the box
well the new start/bendix assembly does not seem to be working
I accidentily pulled the bendix apart like the old one in the pisture, and the directions said you shouldn't but if you did then the first time you start the car, it would retract, but the damn thing wont spin up
Ive even tried pushing down my appt parking lot, then running to catch up hop in the cab and pop the clutch in the first gear, and the thing wont start
It looks like im Digressing
Any help? Please
if i took the starter to Auto ZOne, to have it tested, when they spin it up would that close the bendix?
Any help? Please
- Uncle Skip
Dave.
If I can help you out with that starter, please get in touch.
I'm in Pearland off 288, BT is over on Dixie Farm Road in Pearland/ Friendswood, RatFinkMike is in Friendswood, Little Richard (owns Black Betty) is in Friendswood, Doug Brown, Max lives in NASA, and several others are down there close to you too.
There is quite a bit of expertise floating around the south part of Houston.
You are not alone
Drop me a line, let me know what your e-mail address is and I'll put you on the contact list for cruises and such.
Glad to have you in the Lone Star group. It gets bigger by the day
U@ss
You are not alone
U@ss
I had to buy a stater for the 223 that is now in the Uni back when it was in the 64. Took the starter in, the one that fit was listed for a 352, go figure.fmartin_gila wrote:Have to be careful on the 223 starters, there were two length of the shaft sticking out. Also have heard something about a starter from a 390 possibly working on a 223.
Fred
fmartin_gila
Just looking at my notes. I have written down Starter Drive C2AZ 11350-C (Motorcraft SD132 May be NAPA) SLICK 60s MSN Group 11/19/2005 Garbz Starter Answer 390 starter will replace? much cheaper FE Engine Don't have to flop ring gear 352 360 390 same? 65 66 67?
As I stated, these are notes I have written for possible future reference. The starter in my 223 has been working good since the day I got it, so I haven't had the need to check any of this.
As I understand it, the V8 type starter will engage the ring gear teeth from the front instead of being pulled in from the rear, thus biting into new teeth edges and eliminating the necessity of flopping the ring gear (might be easier than pulling tranny and clutch etc. in case the teeth are chewed up.
As stated, this may turn out to be BS.
If any one does make use of any of this info and it does work out, PLEASE post about it(including any part numbers) so others can benefit. Thank you.
Fred
Fred
alright so ive been busy lately so i havent had time to work this problem out, now im back on it
I accidentally extended the bendix into the starting position and now i can get it back in. The directions said that if you extend the bendix then when you put the starter in it will retract the first time you start it, so its no big deal
So i put it in with the extended bendix, and she tries to spin up, but just wont. I tried push starting it but a no go.
So does anyone know how to retract the bendix?
Im thinking of going up to the parts store and asking them to do a starter test and see if their machine will spin it up and retract the gear?
any other suggestions?
- Uncle Skip
Sorry guys.
I just saw this post so I looked up the part number in my master parts catalog (1963 Ford Truck Catalog).
The Ford part number for the 223 starter motor and drive assembly is Autolite B8C-11002-A.
Also listed is a part number for the 223/ 272/ 292/ 312 C2AZ-1102-A and states that you need to use it with the Ford C2AZ-11350-B starter drive assembly.
Try NPD, Carolina Classics and Carpenter if you can't find a crossover at your local parts house.
Take note, the Falcon 144-170 6-cylinder part number is almost the same but don't use it.... C2DZ-11002-A - IT WON'T WORK.
I hope this helps you out.
U@ss
U@ss
- Uncle Skip
