Whats a good O/D trans?
So I have a nice 400 at my place that my step brother had built and only ran for a bit.I was thinkin of puttin it in my crew cab but wanna run an O/D auto behind it.What a good tranny to get for it?
-Shiny
-Shiny
every movie I've seen the bad guy in the Camaro outruns the cop in the Crown Vic everytime!
'66 Merc "Crewlcab", SWB, clipped, c-notched etc
'65 Merc extra-cab,soon to be 3/4ton 4x4 SWBSOLD
'66 Merc J-Lo and Redford movie truck, from the movie "an unfinished life"
'66 Merc Crew Cab project 4x4 Cummins!
'65 Chevy crew cab
'65 Chevy crew cab
- Johnny Canuck
I think 400 (m) has a big block configuration and I think there was an OD tranny for them, just not sure what it was called. If it was a 400 C (rare) I think they had small block pattern trannys and you could use an AOD.
Need a big block guy to pipe in, sorry I am not that in tune with those.
JC
JC
Hmmm,I've looked around on the 'net and couldn't find a thing.
Thanx JC.
-Shiny
Thanx JC.
-Shiny
'65 Chevy crew cab
'65 Chevy crew cab
This what I found,but does anyone know for sure if it bolts up to a 400?This says 351W
9. E40D Built from 1989 - 1998. Found only in trucks.
Replaced C6. Electronically controlled w OD. Medium to heavy duty.
Pan is wider than it is long 20.5" X 13.5" w/ a notch out of right front corner and has 20 bolts.
Electronic OD on a 351W would be likely be this tranny. F150 door tag w/ trans code of E = E40D.
1989-93 truck with P-R-N-OD-2-1 pattern = E40D.
Non-removable bellhousing. Electronically controlled.
1994-up trucks w/ overdrive cancel switch and P-R-N-OD-2-1 can be E40D
Pan length approx. 20". Overall tranny length 37 1/2".
1995 up units are better. Older units can be updated to same level. Gets 4 or 5 thumbs up.
'65 Chevy crew cab
'65 Chevy crew cab
A 400M will indeed bolt up to a C6, except for the rare ones that will bolt up to an AOD or FMX. Never heard of a 400C before though...
I can't say for sure what OD trans would match the C6 pattern, unfortunately.
Edit: Check this out:
http://www.becontrols.com/ourfaqs/e4odf ... m#12218156
Excerpt from the link:
I have a 1983 f100 with a 400m. will the e4od fit.
The 400M has the same bolt pattern as the 429 and 460 Big Block Engine. The E4OD that would bolt to your engine would be from the 1989 and up Ford trucks with the 460 engine. Not all 1989 and up Ford trucks with the 460 have an E4OD, some still have the C6. If it has the E4OD there will be an OD cancel switch on the dash or on the shifter. These transmissions are electronically controlled, so you will also need our Baumannator TCS™ transmission controller.
Cool,thanx Big M!!
-Shiny
-Shiny
'65 Chevy crew cab
'65 Chevy crew cab
No problemo! Here's some 400 performance info I ran across a while ago (I've considered the same swap myself). It's kind of an unloved orphan, but I think it has a lot more potential than people give it credit for.
http://www.projectbronco.com/Technical_ ... ild_up.htm
If it hadn't arrived at the onset of the smog era, it might have been legendary. Good luck!
P.S. I'm sure that if you do end up adopting this Blue Oval orphan, the group may just forgive you for considering a Camaro clip.
- Johnny Canuck
jasonThe Big M wrote:A 400M will indeed bolt up to a C6, except for the rare ones that will bolt up to an AOD or FMX. Never heard of a 400C before though...
http://en.wikipedia.org/wiki/Ford_335_engine
the 400 is actually a Cleveland motor, but if you scroll almost all the way thru the spiel on 400 engines you will see they had a (rare) version with the small block tranny pattern, which I refer to as the 400 Cleveland. I consider the BB pattern to be Modifieds. None of these is technically correct to the 335 purist. It is just called a 400. no matter what tranny pattern
also. that pic I posted in the camaro clip thread, shows an E40d behind a 302.
Hehehehe,
I'm still gonna measure a torino clip,so then everyone here will love me still(cuz I'm really concerned about y'all think of me:lol: )
I gotta talk to my stepbro tonite,he had this thing built by a good frind of mine whos built some killer with me for our race cars.It went like a raped ape before.Hopefully it'll go gooder again.
Thats a great article,saved it to my faves.I also might have a set of '70-'71 4V and 2V Clevland heads and intakes in my moms shed still too
-Shiny
-Shiny
'65 Chevy crew cab
'65 Chevy crew cab
shawns fords
thats a good bit of information, I am still wondering if the pilot (in the back of the crankshaft) in my 400M is the same as my 429s? ill have to measure it next time its apart, hard to find good 335 series info onlineThe Big M wrote:A 400M will indeed bolt up to a C6, except for the rare ones that will bolt up to an AOD or FMX. Never heard of a 400C before though...
I'd never seen a 400 with the small block pattern myself, the only 400's I've ever seen have had the big block pattern on them. I do know they exist, must have only been used in cars.
Vehicles:
2000 F250 Superduty Crew cab
1998 Ford Crown Victoria Police Interceptor(work beater)
1961 F100 Uni (my baby)
1966 Thunderbird: someday.
Ah, I see. I've never heard that before. I've only ever heard them called 400M's. It does make more sense to call it a 400, now that you mention it.Johnny Canuck wrote: jason
These guys throw some power at an AOD
http://460ford.com/viewtopic.php?t=16270
Jay broader in TX builds tough ones
Someday I'll get another slick
