Pictures of Alternator brackets FE motors
"Whitey Ford"
Post by "Whitey Ford" »
Does anyone have some pictures opf their alternator brackets for their FE motors. I have had this home made bracket on for awhile and i finally got the right one and wanted to make sure iam all good whether its a high or low mount.
Any help would be greatly appreciated.
Girls love a pick-up man.
Re: Pictures of Alternator brackets FE motors
LM14
Post by LM14 »
chris401
Post by chris401 »
Top is a C6AE-A non smog low mount. Bottom is a set of top mount 68 brackets. Link to mustangtek : http://www.mustangtek.com/Fordparts/C8AE-10145-A.html
"Whitey Ford"
Chris i have the top type but sure seems like th elaternator will be hitting the head. I take it the slotted aluminum spacer does bewteen the alternator and block.
Thanks for the pics
LM 14...thats perfect. Im going to make sure im good but looks like i have the same alternator and set up. As you can see i have a slight 'off' at the belt. Hasnt bothered anything but want to do it right.
Seems the spacer for my coil is what is for my alternator.
therealjoeshmoe
Post by therealjoeshmoe »
HURS MINE
Image Image Image Image
"Whitey Ford"
You have the longer type of top bracket. Just seems so close to the head if mine moved back anymore
therealjoeshmoe
ITS VERY CLOSE TO THE HEAD BUT I CUT A PIECE OF A OLD ANTIFREEZE JUG AND PUT IT BETWEEN THE HEAD AND ELECTRICAL ON THE BACK OF THE ALTERNATOR GAVE ME A LITTLE PIECE OF MIND FROM SHORTING OUT...
therealjoeshmoe
LOOKS LIKE IT HAS TO BE THAT CLOSE OF THE BELT WONT LINE UP SO IF YOU SPACE IT OUT YOUR GONNA HAVE BELT PROBLEMS I WOULD THINK..
"Whitey Ford"
yeah im sure it is...thats why i was sorta looking at the low mount style but didnt feel like spending the money. i had an alt about a month ago when dealing with this that was touching the head and it went out quick. Thats why im trying to do this the right way now and not deal witht hat again. It doesnt sqeal or anything the way i have it but i sure like to have all the right parts on this since ive done everything else right.
therealjoeshmoe wrote:ITS VERY CLOSE TO THE HEAD BUT I CUT A PIECE OF A OLD ANTIFREEZE JUG AND PUT IT BETWEEN THE HEAD AND ELECTRICAL ON THE BACK OF THE ALTERNATOR GAVE ME A LITTLE PIECE OF MIND FROM SHORTING OUT...
Ford used a rubber boot on the battery connection to the back of the alternator.
"Whitey Ford"
What is going on here? As you can see the alternator would be hitting the head when its sutnred up to the adjusting arm. Do i have the wrong water pump or alternator for these brackets? I also dont see how the alternator and the alimnum spacer is even close. I have one thing that wrong here.
chris401
Post by chris401 »
[quote=""Whitey Ford""]What is going on here? As you can see the alternator would be hitting the head when its sutnred up to the adjusting arm. Do i have the wrong water pump or alternator for these brackets? I also dont see how the alternator and the alimnum spacer is even close. I have one thing that wrong here.
Image[/quote]Looks like wrong alternator. On the alternator the boss the big bolt goes through should be 3" and the spacer 1 5/16". Measuring the alternator face to stud should be about 4 1/4". The alternator on my truck now is 4 5/16" and the factory boot fits with room to spare.
"Whitey Ford"
What kind of alternator is that? I have the GM 10SI
chris401
Post by chris401 »
It is the early Autolite type. My truck has the latter square top Motorcraft mounted that is the same detentions.
65 lightning
Post by 65 lightning »
Can you help me I'm new to the site and not sure how to post?
65 lightning
I've got a 65 step side that I'm doing a 92 crown Vic full frame swap and thought people might like to see the pic
65 lightning
69supercj
Post by 69supercj »
Posting pics on here is a pain in the arse. Been there, aint done it.
"Whitey Ford"
Get a photobucket account. then copy image and paste.
