223 six questions
Shoveldog
223 six questions
Post by Shoveldog »
My 63 F100 is running on a tired '64 223, bought out of a junkyard in '77. It has served well, and still runs fairly well actually. I have a low mileage '59 223 ready (out of a Ford Custom) on a stand, waiting to swap in. Want to get my OD trans (out of a '62 292 Galaxie) and do it all at once. Can anybody tell me if can I use the same truck flywheel & clutch or will I need the smaller car clutch. Does it have the same size pilot shaft? 1977 was the last time it was apart, so I really don't remember. Would like to keep the truck mobile until I have everything together to swap. Another question: the valve cover on the '59 has the early two center bolt mounts. Other than that are the heads the same? Will my' 63 intake & exhaust manifolds work on the '59?
Mike
'63 F100
'08 Ranger
Re: 223 six questions
The heads are the same , except for valve cover bolts
The manifolds will work fine
I'm just guessing about the flywheel.... But I would bet it would work
Take a measurement of the input shaft on the transmission. The truck trannys I've seen all use a larger (1 1/4") input shaft where most of the car trannys use a smaller (1") input shaft.
64 f100
Post by 64 f100 »
You will have to use a car clutch disc as the splines are different. In addition, the transmissions have different outputs . the truck having a yoke attached the car not. this means shortening the drive shaft and changing the end , I believe. You should be able to find the clutch disc in the same diameter as the truck but might mean searching around for one. If, not easily found, then you will have to go with the car flywheel, and clutch setup.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
Shoveldog
Post by Shoveldog »
Thanks guys. I have both car & truck flywheels & clutches. The one from the '59 car & 2nd truck flywheel (bought along with a an extra truck bellhousing a couple of years ago) appear to use the same casting & ring gear, but with the car clutch being smaller, the bolt circle on the flywheel is smaller. The car in question had a small light duty 3 speed, much smaller than either the truck 3 speed in my truck now or the OD trans I plan to install. I can measure the input shaft and figure it out now. Really good news about the manifolds.
Mike
'63 F100
'08 Ranger
The Big M
Post by The Big M »
I have actually read that the car heads are slightly higher compression, though I've never personally confirmed it.
The only other difference of note that I can think of would be the distributor hex drive. The '64 has a larger hex so if you wanted to use the distributor from the '64 you'd have to swap over the oil pump.
