Emblem removal
brute66
Emblem removal
Post by brute66 »
I was curious if the '65/'66 fender emblems can be removed without taking off the fenders. I stuck my hand up there and I can feel two mounting pins protruding but I'm not sure what kind of fastener is used to attach these with. I can't detect any nuts holding these things on. Apologize for my ignorance on this, just thought I'd refer to experts out there, thanks!
rw66f100
Re: Emblem removal
Post by rw66f100 »
I just pried mine off on my 66. They snap into some kind of bushing in the holes. Not sure what the bushings are made of but I need to get some new one. Take your time and work them off evenly.
36truck
Re: Emblem removal
Post by 36truck »
The have little metal barrel nut holding them in. They just pull out a putty knife works good to get them off.
Tom Williams
Re: Emblem removal
They are retained by tube clips which are inserted into the sheet metal. Usually they will stay in place and can be re-used. replacements are available from fastener suppliers; they will need to know the stud size as well as hole size.
brute66
Re: Emblem removal
Post by brute66 »
thanks for the info, I'll pry them off, carefully
born4ford
Re: Emblem removal
Post by born4ford »
Harbor freight makes an inexpensive tool that helps get badges off without bending them - http://www.harborfreight.com/panel-clip ... 67399.html
