Jefferson, Texas - Finally back to my project after about 10 years of putting it off and learning. My youngest will be a senior in High School next year so I have much more time to do ME stuff. After much research and lurking around here, I have decided to go with the Crown Vic Swap. I am hoping I can find one or two in good enough shape to use as much from them as possible. I must warn you ahead of time that I will probably become a huge pest as I know I will have many questions as I progress. Thanks in advance for putting up with me. Brian
http://photos.besmithent.com
64 F100 Short Wide. Finally back at it.
- 390fastback
Re: 64 F100 Short Wide. Finally back at it.
Looks sweet! Lots of us on here have done the CV swap. I ended up buying a complete 06 CV interceptor from the local insurance agency for $400, even drove it off the trailer!! Anyway, once I had the suspension in, I looked at the 4.6 on the garage floor and, well, it ended up in the truck to. If you have questions, that's what we're all here for.
plus many other's!
plus many other's!
BESmithEnt
Will I need to remove this cross member? Looks like the two braces will definitely be in the way.
http://s1027.photobucket.com/user/BESmi ... c.jpg.html
- 390fastback
Nope, springs, axle and shock tower come out, you're good. I set my cv axel 3/4 inches back, or forward, of the original location. I'll need to dig to find out what I did, its been a couple projects ago! Just be sure to measure, numerous times, where the axel is right now!!
plus many other's!
plus many other's!
