i hope you all accept my apology for being wrong, although i cannot tell Steve f7bigjob who was one of the participants in the trivia and this bothers me
now is it possible this was a mid year change i do not know, if anyone does i would like to know
My theory: It may have to do with where the truck was shipped to. That hinge in your wetter climate would be more problematic where more moisture and ice would cause rust while under warranty. The two I have are from the Kansas City plant one delivered to Teague, Tx the other to Texarkana, Tx. It would make sense trucks up north would not have this bad idea. I had a few 65 parts trucks when I was a kid and they all had broken or frozen gas pedals.
IIRC: When I worked at Ford vehicles sold in certain northern states would get the under coating update and vehicls in other states would not.
It could also depend on when the truck was shipped. I've had 65's with the hinged pedal and others with the suspended pedal. Most companies like to run down their excess parts before switching to a new design. I have noticed regional differences as well. The western built trucks do not have the inside of the cab around the roof gutters painted, while the eastern ones do. This goes back to the '50s and IMO is the reason why western trucks tend to rust up high.
i still dont get it. if we are talking about the gas pedal, i thought that was a running change in 65. i have parted early 65 trucks with the floor mounted pedal and late 65 trucks with the hanging pedal. what are the parts in the link brian?
ezernut9mm wrote:i still dont get it. if we are talking about the gas pedal, i thought that was a running change in 65. i have parted early 65 trucks with the floor mounted pedal and late 65 trucks with the hanging pedal. what are the parts in the link brian?
the parts were the nuts recessed into the floor that the pedal bolts to
i suppose its possible they are in all of the 65 floors whether the pedal is floor mounted or suspended, i cant say i ever looked for that in any of the parts trucks
the factory did some weird stuff relating to changes, changing the pedal in no way affects the floor and you cant see the nuts with the mat in place and the suspended pedal would not have a floor mat with holes in it
Look at the picture of my show truck in the last post in his original link.
Yep, change was made around June of '65 production for the front coil spring equipped trucks. S/n 696,001 is the first of the suspended pedal. Part number for that pedal assembly was quickly obsolete, '67's used the three bolt suspended pedal also used on several car lines. The OEM high-hump floor mat used to come with those mounting holes cut out no matter whether ordered for a '65 or '66, while the low hump mat required cutting the holes for the early '65's.
Yep, down here there are usually holes in the floor, cab corners, roof rails, etc.!
I have not seen any evidence of the holes on the ones with suspended pedals; I haven't replaced any floor pans with repops, so I am unaware if the aftermarket patch panels have the holes or not. If the flood goes away, I will check my earlier trucks to see if the holes exist for the suspended pedal assemblies. Someone mentioned he had a couple of later '65 trucks with the older pedals; I never encountered that with Ma Bell's fleet, and they went through a bunch of floor mats.
