new guy from ne fl
FL, GA, AL, SC, MS, TN, NC
66redrider
new guy from ne fl
Post by 66redrider »
Im new to the whole slick world. I few months back i purchased my next project which is a 66 f100 of course lol. It had alittle work done to it to kerp it looking decent and running. The truck has a straight 6 with 3 on the tree. I recently bought a c6 transmission to have rebuilt and swap out the manual to auto. Have other plans for the truck other than just the trans swap like suspension work and interi I r work. Will try and get some pics posted tomorrow
jkimbrel65
Re: new guy from ne fl
Post by jkimbrel65 »
:welcome: from n al we like pics
Mike
I tried being normal once...
66redrider
When the truck arrived
66redrider
Then some changes i have done...not much but replaced the oil bath filter and replaced the ford grille emblems with new ones
I've never started with a truck that looked that good. Looks like a lot of fun.
66redrider
bruceandersson wrote:I've never started with a truck that looked that good. Looks like a lot of fun.
Thanks.... since getting it, its been a kept in the garage. Im in the works of getting a c6 transmission i picked up for cheap rebuilt to swap into the truck. I really want to do a column swap with a shifter on the column but will probably do a floor shifter n d I wn the road do a column swap eliminating the old column 3 on the tree.
Other plans for the truck will be some interior work, replace the windshield n seals on the windows, new rims n tires and suspension work in the form of air ride. Work in progress....slowly
therealjoeshmoe
Post by therealjoeshmoe »
PAINT THAT GRILL WHITE!!!!!!!!!!!!!!!!!!
SWEET TRUCK THOUGH!
Image Image Image Image
orangeRcode
Post by orangeRcode »
Very nice looking short box. Keep us updated.
66redrider
therealjoeshmoe wrote:PAINT THAT GRILL WHITE!!!!!!!!!!!!!!!!!!
SWEET TRUCK THOUGH!
Hmmmm..... interesting thought
66redrider
orangeRcode wrote:Very nice looking short box. Keep us updated.
Thanks will do
66redrider
so curious... I have with the extra parts that came with the truck a chevy big block alt; any idea what the "po" could have had in mind for it?
longcabjohn
Post by longcabjohn »
My guess, he was going to change to one wire alternator and some think the chevy is easier to do.
Johnny
66redrider
longcabjohn wrote:My guess, he was going to change to one wire alternator and some think the chevy is easier to do.
Johnny
Hmm so should hold onto it? There a link to this one wire alt swap?
longcabjohn
My theory is if it is not broke don't fix, but if adding a lot of load it might be needed. Others will add more but I would not rush.
Johnny
66redrider
longcabjohn wrote:My theory is if it is not broke don't fix, but if adding a lot of load it might be needed. Others will add more but I would not rush.
Johnny
Well eventually i will be adding a stereo and air management equipment for air ride but thats down the road. I do notice when giving it gas when driving the alt light on the dash flashes
66redrider
So is there a how to on how to install mirrors on these trucks? I received some chrome mirrors for xmas and figured i ask before diving right in...appreciate any help
unibody madness
Post by unibody madness »
First, Ford purists do not believe in putting non ford parts on a ford....that being said, the Delco Remy alternator known as a one wire alt. is called that because of tractor applications. In order to do the job right on your truck,you would run the charge wire off the big bolt up to the positive on your battery through a j block, starter relay, or amp meter. the I terminal on the small plug goes to the positive connection at that point in order to read correct battery draw. The II wire goes to your idiot light to excite the alternator. Search Delco Remy for a wire diagram... look for the simplest that uses three wires.
In regards to mirrors it all depends on what mirrors you got. they either go to your two ears, one on each door or get screwed to your sheet metal on the door, if you have western or tow mirrors.
66redrider
I have the round chrome set from lmc that use the ears.... im looking to switch the ears out to the chrome ones that came with the mirrors...
Will look into the alt swap
66redrider
In the picture below is the top bolt i circled what holds the ear for the mirror in place on the door or do both?
unibody madness
both hold the ear on
