Pie Festival
Car shows, swap meets, member get-togethers - post your upcoming events here.
Pie Festival
Paul Kruse is having his Pie Festival and Car Show on the last weekend
in May on May 28 in Gypsum, Kansas! Pretty cool deal especially if you win
an award because they are edible! MMMMMM! TR
Re: Pie Festival
Hopefully there will be a 4x4 Slick there.....
I'm pushing for the March 1st deadline....
I don't see it happening... Gotta work harder :x
Re: Pie Festival
At least you have the option of pushing one there; probably would not work for me! BTW, I gave TR some bad info as to planning! The Festival is Sunday the 29th; Memorial Day weekend!
Pat, don't know if TR mentioned it, but there seems to be interest in a re-match for the valve cover racers! If you're willing, I could bring a (hopefully), dependable truck for hauling this time!
Re: Pie Festival
Thanks for the heads up Paul! We'll get this right one way or another!
At any rate we plan to be there to set up the Valve Cover track and have
a rematch with a bunch of the Kansas boys from around there.
Should be a good time. Also will be a good tune up before our races
At Slick Stock! I need to find a board with erasable markers to set up the
brackets for the races. Last time we used a chalk board in October.
Will check into this between now and then. TR
