The FOX BUILD!
Andy fox
The FOX BUILD!
Post by Andy fox »
Making a new thread to help me get some of my questions answered. And to help people follow my family and I's build.
This is the 2nd slick I've owned.
I just bought this one for $950. It's a '65 f100 long bed. With "supposed to be" 390 4bbl. 3 on the tree converted to floor shift. Kind of a basket case. Just a small case. Could be alot worse. Random cut wires, no ignition key, missing clutch linkage, floor shifter linkage some is missing. Bucket seats,bed and cab are "un-nutted" still have bolts in place. Someone went to restore it then gave up I guess. Frame is painted black already.have clean title though.
Got her home. Got it started threw the solenoid. Noticed it was leaking antifreeze from flywheel area. So the freeze plugs were bad. Pulled the stubborn motor, freeze plugs look fine. Doing a pressure test right now and its holding 20psi! And I believe the FE big blocks are 16-18psi systems? Please correct me if wrong.
So going to clean up the bay, block, valve covers, replace freeze plugs, water pump, therm, oil pan gasket, valve cover gaskets and clean valve covers. Then reinstall.
I'm keeping this truck in the family. Girls and I are very excited for these memories.
Got it pulled
Got it pulled
Andy fox
Re: The FOX BUILD!
Post by Andy fox »
The pictures of the bolts are plugs for the time being.
Andy fox
Re: The FOX BUILD!
Post by Andy fox »
I plan to marvel mystery oil the motor a few times and oil changes. Think it will clean her up??
Re: The FOX BUILD!
Wow, that is one sludged up top end! Just remember that once your done, stay away from high parafin oils like quaker state.
Andy fox
Re: The FOX BUILD!
Post by Andy fox »
Who here has converted 3 on the tree to the floor? Any pics have your linkage? And where can I buy parts for this kind of set up?
Andy fox
Re: The FOX BUILD!
Post by Andy fox »
Saturday night update.
Clean the thick gunk from inside the valve covers. Now to shine up the aluminum.
Removed gas tank. It definitely needs replaced. 2 gobbed up welds on the back to stop some leaks.
Now to get an engine stand. Drain the oil. Pull oil pan off, and turn the motor upside down and clean the valve cover as best as possible.
Andy fox
Re: The FOX BUILD!
Post by Andy fox »
Well. Finally got motor on engine stand and was able to get the oil pan off. Lots of metal shavings, but can't see any damage other than Chips off the block. I called around and got different prices for a motor rebuild to push 400 hp and that was around $4k-$6k which Is the ball park I figured. So I'm going to put some new parts on this motor and put her back in and see how she'll run. I'm not loosing anything but some time. If it's no good I will pull the new parts off and buy a used motor untill I can afford a rebuild.
BarnieTrk
Re: The FOX BUILD!
Post by BarnieTrk »
Hi Andy,
I can understand your anxiousness to get your new project up and running. But with that much crud inside that engine, I wouldn't agree with your thoughts to add parts and re-install it and try to run it. That much crud will become dislodged and plug up oil galley passages, plug up valve lifters, plug up pushrods, cause crud to become lodged in the rod and/or main bearings, etc.
I would HIGHLY suggest you continue to disassemble your engine and have the block and heads hot-tanked and pressure tested. You may have a cracked block since you deemed the freeze plugs NOT to be the source of the coolant leak.
Regarding the 3-speed transmission shifting linkage - does it look like you could take it back to the column-shifted linkage? I'm sure there are plenty of available column shift linkage parts and pieces out there. Before chasing linkage parts, you may want to (at least) drain, inspect and refill the transmission gear lube with the hopes that it too isn't full of crud.......
Just my :2cents:
BarnieTrk
-- '63 F-100, 2WD, 223", T-18 4spd; owned '74-'76
-- '65 F-250, 2WD, 240", 3spd; owned '76-'79
-- '94 Ranger XLT, 4-cyl, 5-spd; owned '97-'14, put on 309K miles. Sold it running.
-- '65 F-100, 2WD, 390", T-18 4spd; owned since '81. Still licensed & driven by me.
-- '65 F-250, 2WD, 390", 4spd/OD; owned since '08. Still licensed & driven by me.
-- '06 Ranger XLT, 4-cyl, 5-spd; owned since '13. Licensed and driven by me.
Andy fox
Re: The FOX BUILD!
Post by Andy fox »
Update!!
Lifted the stand on the trailer with the hoist and put all the smaller parts in the tool box and went to the car was with degreaser!! Bam!! Looks much better. Now to oil it and put back togather
MN66
Re: The FOX BUILD!
Post by MN66 »
I spent the day degreasing my 352 and NP435 trans, so I feel your pain. Good luck with your project, I'll be following.
Regards,
Corey
1966 F250 LWB
