My '66 F250 Crew has 16" 8 bolt wheels with the rings on them, and I would like to find solid wheels for it. So, how many years of trucks/vans have the same approx width, same bolt circle and same ID diameter on the hole for the hubs? (assuming from what I see the wheels are intended to be hubcentric??)
I know someone who has a mid 90's F250 ('94-'96) that has a date with the squisher as soon as they get the drivetrain out of it, so there is a potential wheel donor, provided they will bolt up & the wheel hub ID's are the same??
Thanks!
James
3/4Ton 8 bolt wheel interchangability acoss the years?
- ThinLizzy13
Re: 3/4Ton 8 bolt wheel interchangability acoss the years?
I believe they switched in '99 to the metric size. Up until then they should all interchange.
I think 97 was the last year for the 8 x 6.5 bolt pattern on F-series trucks. Mine came from a later year E-series van, and I think they kept the same bolt pattern maybe as late as 2011.
Regards,
Corey
Regards,
Corey
1966 F250 LWB
Corey hit it dead center, so the mid-90s truck would make an excellent wheel donor.
Corey/Paul: Thanks, now all I need to do is come to an agreement on price:)
- ezernut9mm
i found four ford wheels with almost new perelli tires off of an e250 van on craigslist for 200$. have patience and keep an eye out. they are out there.
Front Drum Clearance Issues
I had front drum clearance problems. All the wheels that had rivets on the inside would contact the drum before contacting the hub. The Fire Stone wheels with weld beads cleared. I was only able to find two Fire Stone rims so I bought a matching set of new steel trailer rims. I run Cooper Discover 235/85 R16 E.
Are they Firestone rims? The two I found were on a 1990 E250.
orangeRcode
Great looking truck Ezer!
