Steering column swap
oldschool2888
Post by oldschool2888 »
Change 1966 steering column from stick to auto when using later ford power steering gear. Finding proper location for dash mount when using later steering column. Are there any tricks ? Jerry
Re: Steering column swap
I took the mounting bracket off the old column and welded onto the new column. As I recall the spot welds were pretty large and I used a grinder to get the brackets to release.
