Intake manifold ID, 2nd try -- smaller pics
Mojave922
Post by Mojave922 »
Was cleaning out my dad's garage and came upon this intake. Can anyone help identify it? First thought was sb ford but the intake ports are round -- don't know of any sb ford heads with round intake ports.
Manifold 3.JPG (31.55 KiB) Viewed 1171 times
Manifold 2.JPG (32.84 KiB) Viewed 1171 times
Manifold 1.JPG (35.58 KiB) Viewed 1171 times
David
65 F100 swb (352 3 spd manual, not running)
Previous rides:
69 Bronco, completed frame-off restoration
07 Kawasaki KLR650
92 Acura Integra GSR
65 Mustang 2+2 A-code
67 Mustang coupe C-code
jamesdfo
Re: Intake manifold ID
Post by jamesdfo »
That pic is HUGE, I can only see ~ 10 % of manifold at a time, try reducing pic size, then it might be possible to actually ID it.........
Mojave922
Re: Intake manifold ID, 2nd try -- smaller pics
Post by Mojave922 »
jamesdfo wrote:That pic is HUGE, I can only see ~ 10 % of manifold at a time, try reducing pic size, then it might be possible to actually ID it.........
Thanks for the heads up jamesdfo, please check out the new pics.
David
Previous rides:
07 Kawasaki KLR650
jamesdfo
Post by jamesdfo »
Mojave: Going by the thermostat housing, it is SBF, it kind of looks like an EFI lower manifold that someone has topped off with a plate cut, drilled, and tapped to mount a carb on. But the firing order on the corner, which you showed in one of your pics is the old 260/289/302 firing order, not the later firing order used on 302HO/5.0L??
Are there no other numbers cast or stamped into it?
James
MY OL 66
Post by MY OL 66 »
I agree that it has the early sbf firing order, but I do not think it is an efi lower as there do not appear to be an injector bungs on it.
The round ports "might" indicate it was used with Boss 302 type of heads (Cleveland heads used on small blocks in '69 and '70).
I seem to recall some "race specific" manifolds of this type that were tried back in the day but were not too successful.
Again as mentioned above, if there are any other markings or cast or stampings, they might help in identifying this unit.
Steve F
1965 Mustang Coupe
1966 F-100 Shortbed CC/Ranger
2010 Mustang GT Convertible
2010 Shelby GT500 Convertible
Mojave922
Post by Mojave922 »
I did not find any other casting numbers. I noticed the bolt holes on top line up with a Holley 4V flange, apparently two 4Vs. The metal adapter for single 4V looks to be homemade. Those circular intake ports are what threw me off. Think it has any collector value?
David
Previous rides:
07 Kawasaki KLR650
jamesdfo
Post by jamesdfo »
Mojave: Collector value depends on what it is, impossible to value something that hasn't been positively ID'd.
But MY OL 66 may be on to something with the Boss 302, and the first thing I thought of after reading his post was CROSS BOSS. This was an intake & carb sold through Ford Performance, which utilized a Motorcraft inline four barrel carb.....but looking at google images, I'm not sure??
https://www.google.ca/search?hl=en&site ... C0TB2uefGY
robertrpeak
Post by robertrpeak »
Its not a crossboss! What it looks like is a 2x4 thats had the center removed, for what ever reason... still not to sure on the round ports...
Edit: looking pretty good for 302 tunnel port heads. I'm not to well versed with the small block Fords, FE's are my choice :lol:
It appears from what I can see of the photo that the center has had two pcs. welded in...
Robert
robertrpeak
http://www.hotrod.com/features/history/ ... /#photo-09
This looks like it, note the fireing order numbers.
Robert
robertrpeak
Mojave922
Post by Mojave922 »
robertrpeak wrote:Its not a crossboss! What it looks like is a 2x4 thats had the center removed, for what ever reason... still not to sure on the round ports...
Robert
Robert
Robert, you're spot-on that welds have been put in, bridging the gap between two carbs. Keen eye sir. There is a plate pictured for use of a single carb. I don't know what it would have worked on other than a tunnel port... Maybe I should contact a Boss 302 list.
David
Previous rides:
07 Kawasaki KLR650
robertrpeak
Yes, I would contact some of the forums that deal with tunnel ports, racing of said engine etc. Could be that it was modified by some race team, might have an interesting history, good luck..
Robert
Mojave922
Post by Mojave922 »
http://www.mustangtek.com/Intake/C8FE-9424-A.html
Looks like the same intake to me. Have applied to post on boss302.com and am awaiting approval. Thanks all for the help!
David
Previous rides:
07 Kawasaki KLR650
Mojave922
Post by Mojave922 »
Guys over at Boss302.com confirmed it's a factory tunnel port intake (yay!) but it's practically worthless because of the DIY hack job (boo!)
Oh well, fun trying.
David
Previous rides:
07 Kawasaki KLR650
