Shift collar question
Kid
Post by Kid »
The shifter collar on my brothers 64 broke, He has looked all over and can not find one for a 64 F-100 but has found one that looks identical
for a 61-65 Comet/Falcon. Does anyone know if it will work on his truck.....................Kid
Kid
Re: Shift collar question
Post by Kid »
well it is not the colar it is the part that goes inside the column the hooks to the shifter and goes down to the linkage
36truck
Post by 36truck »
That's the shift tube. Did the little tab break off it? It can be welded back on.
Tom Williams
Kid
Post by Kid »
something broke inside it, they are going to try to epoxy it back together if the one he found doenst fit
64 f100
Post by 64 f100 »
The shift collar should be the same for the Falcon/Comet.
I don't believe epoxy would be a long term solution considering the load. As said, I would expect it to be the upper tab; easily welded and ground to repair. I'll verify applications; I may have an extra for the CoM.
Agricola1066
Post by Agricola1066 »
One of my "helpful" students snapped my shift collar. It broke because the body has sagged on the rubber mounts. Before you replace it, make sure it isn't the same problem....
