Admidantly I didn't know a lot about these trucks when I bought mine. I was looking for old iron in the Ford variety with no preference on year or model. I bought mine and it was a little bit of a mess with a really bad paintjob and a thin layer of body filler all over the whole truck (assuming it was someone's crappy attempt at skimming the body).
I sanded the truck and shot overtop of the mess as I wasn't planning on a restore quality paintjob. Well fast forward 8 months and I noticed a crack beside the drivers door up high. I was watching the Walking Dead and saw the f100 on that show had a thick joint indentation exactly where my crack is and chasing all the way around the cab to the other side.
I am assuming that the PO filled in this expansion joint and now the filler is cracking.. Does that sound right? Or did only some models have the joint?
If this is the case, what would be the best way to remove the filler from the joint? Could it be done without having to reshoot the whole cab?
Thanks.
Roof seam.....
Re: Roof seam.....
this roof seem?
Mine has what appears to be bondo in there.. It is old seam sealer (or bondo)... its cracking and falling out. I am scraping it out of there, and putting in new brush-able seam sealer from Eastwood.
Re: Roof seam.....
Mine is completely shaved (filled in) but yes I'm assuming that is what mine should have looked like.
Re: Roof seam.....
April: Do yourself a favour, and at least for any seams on the outside of the body, pick up some 2k (ie: catylized) seam sealer. The air dry stuff (IMO), is shyte, and prone to shrinkage.
The 2K product, once it kicks should be as close to shrinkage free as you can get.....
James
James
shipwrecked wrote:this roof seam?
tomrooster
Re: Roof seam.....
I like the seam sealer in a tube and you use a caulking gun to apply. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
62bigwindow
Re: Roof seam.....
The seam is supposed to be there no matter how unaesthetic it may look. Real problem is rust between the metal. Thin wire brush on grinder or whatever, kill the rust before seam sealing. If, you want the space filled, I suggest silicone wire welding, but it is expensive stuff.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
Re: Roof seam.....
Oh my... Not happy. This is going to suck. I'm going to have to have my cab blasted I bet..
- image.jpeg (1.48 MiB) Viewed 2488 times
62bigwindow
Re: Roof seam.....
What is the purpose of it? As far as welding I don't think silicone would be necessary. Sandblasting followed with a good cleaning with the wire wheel should suffice. As long as its prepped properly and sealed after welding it should last the life of the truck.
Re: Roof seam.....
If it is just filled with plastic, you can use a propane torch to separate the plastic from the metal. I've found this the fastest way to remove plastic. Bad fumes so wear a mask and use just enough heat to soften the plastic. Use a putty knife to scrape off. The as mentioned wire brush out as best you can, seal with some form of rust preventative and use a seam sealer. The original sealer was flexible and would last until it dried out, the number of decades based on your location.
