Thanks for the replies!
Rich, I was aware of the small pattern 4 bbl manifold, block is C2AE-C, heads C1TE.
Brian, I'll see if I can find a number on that 90 oil filter adapter.
John, thanks for the heads up on the pulley. Dennis Carpenter is 10 minutes away.
This one?
http://dennis-carpenter.com/crankshaft- ... TZ-6312-C/
Bird, I will keep you posted once I start digging into it. I hope it's a good one too.
Charlie, I did not know there were different capacity pans. I just looked up some pictures of them.
66-I had not seen that type adapter on a y block before.
More pics when I get a little time.
Thanks, Goob
