Shorter steering column
66camperspecial
Post by 66camperspecial »
The original steering column in my 66 was a little too long and the same with the 69 automatic column that is in it now,I was wondering if anyone knows if a mid 60s galaxie column would be a little shorter so the steering wheel will be a little more closer to the dash. I need to get the steering wheel closer to the dash to be more comfortable and want the column to be in the era so it will not look out of place.
Michelle
Re: Shorter steering column
Post by Michelle »
Shorten the column, I took a little over two inches out of a 79 Ford F150 steering column that I installed in my 56 F-100.
Michelle
tomrooster
Post by tomrooster »
I have one in my spare parts pile ( junk ) from a 63, if I can find it I'll post it. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
66camperspecial
Hoping to find one that will not need too much modifications to work.
Keep in mind that the closer to the dash you move the column, the closer it gets to the seat. Might want to look for the 70's tilt column or an after-market one.
tomrooster
I found it about 36" from rag joint to the top of steering wheel. It came out of a 63 Galaxie. Tom
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
oldschool2888
Post by oldschool2888 »
I just did the conversion from stick to automatic and non power steering to power steering with later steering column on my 66 f-100 Let me know if I can help. Jerry
