'65 Custom Cab instruments into a '63?
leftfootbraker
Post by leftfootbraker »
I'm thinking about installing a '65 CC instrument cluster, with the sweep style speedometer, into my '63 Uni.
I'm hoping the speedo cable, oil pressure sender and alternator sender will work as-is.
And I'm also hoping the dash and blinker lights will just plug into the holes in the '65 cluster.
Can you comment on any issues I will encounter in this switch?
Thanks, Steve
FarmMotorSports
Re: '65 Custom Cab instruments into a '63?
Post by FarmMotorSports »
Believe there is a jumper for the trun signal indicator.
CC uses one indicator for both and standard cab used two.
As long as you're replacing gauges with gauges and idiot lights with lights, yes it should work.
It would be easier with the correct harness for the panel you are using.
61 F250 Unibody
& 4WD
64 f100
Post by 64 f100 »
He is correct about the jumper as the 65 uses one light to indicate left or right turn. The earlier dash bezel was used into the later years so I think it should work for you, although like was mentioned wiring may be different enough to keep it from working.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
