312 Y block crank, South West Missouri Area
- aj64f100390-292
I'm looking for a decent useable 312 crank
19mpg hwy, .040/298ci, arnd 8.7:1, ECG heads, stainless valves, ceramic coated ramshorn manifolds, B code int., eddy 4bbl, Durasprk II/C5ZF dizzy, C2AE rods,high ratio rockers, NOS two groove h.balancer, unkwn cam-for now
soon:pwr asst steering
Re: 312 Y block crank, South West Missouri Area
Why a 312, and not a 292? Several problems with 312 blocks, many being cracked as people re-installed main bearing bolts and cracked the flange the bolt goes in to. If, you get a 312 block and rebuild it, be sure to clean out the main bearing bolt holes thoroughly when you do reassembly.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
- charliemccraney
He's looking for a crank, not a block.
