Ford Y block Fail Stant safe thermostat, do they exist?
aj64f100390-292
Post by aj64f100390-292 »
I've looked at napa's site, o'reilly's, and autozone...napa is the only one that carried any thermostats but I haven't seen any fail safes. Do they exist? dads going to be a bit disappointed...he has always ran fail safes...swears by them.
thanks in advanced
19mpg hwy, .040/298ci, arnd 8.7:1, ECG heads, stainless valves, ceramic coated ramshorn manifolds, B code int., eddy 4bbl, Durasprk II/C5ZF dizzy, C2AE rods,high ratio rockers, NOS two groove h.balancer, unkwn cam-for now :twisted: soon:pwr asst steering
aj64f100390-292
Re: Ford Y block Fail Stant safe thermostat, do they exist?
sorry for making two threads...thats weird....last night It didn't show the window saying it posted my thread...so I hit submit again..you would think I just joined yesterday :lol:
charliemccraney
Post by charliemccraney »
Y-block use the same thermostat as Mopar. If there is a failsafe for those, then there is one for Y-Blocks.
Gravemetal
Post by Gravemetal »
I only ran one fail safe and it failed within a week! This was the early 2000's and maybe they have improved since then. At the time I was advised to go with a high flow high performance tstat instead.
