Measurement and Info needed
9Fingers
Post by 9Fingers »
I'm not sure on all years but thinking 61-66 f350 steering wheel may be the same? I need someone that has one to measure the circumference at the largest part of the wheel before it drops down to the metal column itself.
The 65 I'm working on had a late 70's f150 automatic column but discovered last night it's a tilt column. I've also got another column from a manual transmission truck and might try merging the two to get close to a mid 60's factory appearance with the tilt function. I think I've got it figured out, but need to know the diameter of the four spoke f350 steering wheels. If close to same diameter, I hope to get a big wheel with a tilt.
Thanks for your help,
Bradshaw
unibody madness
Re: Measurement and Info needed
Post by unibody madness »
I think it is the same as the 4x4 4 spoke wheel. I adapted one to my truck but right now it is at the shop getting panels re-aligned If you do not get anyone within a week send me a P.M. and hopefully I will have my truck back by then.
9Fingers
Post by 9Fingers »
Ok, thank you.
Darn it, forgot to measure; I'll get the measurement tomorrow if no one else does.
9Fingers
Post by 9Fingers »
The farm truck my uncle had years ago had a steering wheel like this one, but I don't think the truck was an F550 or larger, Im pretty sure his truck was a 350. Does anyone know the overall diameter (18", 19", 20"?) of this wheel, pictured in an F550 for sale online, and what is the diameter of the collar or portion on the underside of the wheel where it meets the column? I found a four spoke over the weekend that was beyond repair, but decided I like the look of this wheel better.
