300 c.u.i Hot and cold together??? Problem solved update
Mr. Jones
Post by Mr. Jones »
My 350 is the shop for some tune up work,Jack calls me today and says #1,2,3 cylinders are reading in the 450 degree range and that #4,5,6 are showing a temperature in the 200/250 degree area measured on the exhaust manifold,using a thermal measuring device. I told him to proceed with a compression test and call back tomorrow.Also had a Pertronix Ignitor installed with Flame Thrower coil.Engine was down on power and my tune up last week did not help much that's why I let the pro's have a go at it ........Any thoughts on a condition like this??
Re: 300 c.u.i Hot and cold together????
Sounds like a coolant flow problem
I had a dodge that had a piece of tin tube in the head
If it wasn't installed, coolant didn't flow in the back
Not sure if a 300 has such a device
Weak water pump ?
450 sure seems extreme though....
Can't hardly believe that type of heat
At those temps, sounds like you have some cylinders not working well, or at all. I’d be looking toward a common problem affecting those three cylinders, assuming common manifold.
Spark plug condition should have provided a clue; compression check will pretty well tell the tale as to mechanical integrity. That leaves the FAST part of the CFAST equation! Got the C(ompression), that leaves the Fuel, Air, Spark, Timing:
ThinLizzy13
Post by ThinLizzy13 »
Do you have the later style two piece dual exhaust manifolds on it?
Mr. Jones
Post by Mr. Jones »
Not split,the old style one piece......how might that play into it??
ThinLizzy13
Mr. Jones wrote:Not split,the old style one piece......how might that play into it??
I was just taking a shot in the dark that *maybe* if you had the split manifold then *maybe* the front three cylinders' exhaust was plugged somehow.
This is a real head scratcher...did your mechanic have any suggestions after your compression test?
Are you running a 2 bbl carb ?
Could one side be running leaner ?
Mr. Jones
Post by Mr. Jones »
Called Jack back yesterday,cancelled the compression test....$85.00hr.The engine runs better than when it arrived so I'm getting it home and do that test myself.....that won't be until next week..Will post the results then and at their hourly rate the comp.test money will buy a decent infrared detector........meanwhile I'm open to all info....
This post is in a state of temporary suspension........I'll be back........
Pat,Brandon and Paul thanks
I bought a cheap detector from harbor freight
I ain't a fan of Chinese stuff
But it was only like $30
Works ok.. red laser dot ,not very bright
Digital readout kinda small
Not for a mechanic that would use it everyday
Ok for somebody that rarely uses it
longcabjohn
Post by longcabjohn »
I would check timing on the 4th cylinder in rotation which I think is 6, it should show the same as 1 if different a broken cam could still be turning but be a few degrees late.
Of course this is from the SWAG method.
Johnny
orangeRcode
Post by orangeRcode »
Dan, this isn't the one you recently did a light freshen on was it?
Mr. Jones
Post by Mr. Jones »
Robb,
That one was in my 66 250,this is the gray 350 we rode in at Salina....
Mr. Jones
Re: 300 c.u.i Hot and cold together??? Problem solved updat
Post by Mr. Jones »
Got a call from Jack,Friday.Told me they found a broken valve spring on #4 making it run really cold,so that was pulling heat away from 5&6 .....picked it up a couple hours ago drove it to the job picked up all the extra material and returned those drove back to the job unloaded all the trash outta the 250 into it,should have a couple tons in by quitting time......The shop installed the Pertronix,adjusted the valves and a tune up adjusted carb......engine is so smooth at idle it's hard to hear,tested it on a long steep hill made power all the way up....spent the last two weekends doing brakes on the 250 and it's done.Fiqure between what I did myself and the shop both jobs cost me about $460.00 each I'm happy with that
unibody madness
Post by unibody madness »
Good to hear, would like to find a mechanic that does not charge over 100.00 dollars an hour, and actually knows how to work on these. All I can find are high dollar...low knowledge type r and r shops.
orangeRcode
unibody madness wrote:Good to hear, would like to find a mechanic that does not charge over 100.00 dollars an hour, and actually knows how to work on these. All I can find are high dollar...low knowledge type r and r shops.
Agreed, it is becoming a lost art. Asked about points and distributors at a local O'Reilley's parts counter and see what you get. Deer in the headlights. Actually had a kid working the counter tell me he knew nothing about how they worked or how to look them up. When you hear that you walk out the door and try and find a better parts counter guy.
That's great news Dan! Glad your girls are back up and running good.
Good deal, Dan, gotta love the modern technology. Back "in the day", the thermal measuring device consisted of a body part!
i do miss the old diagnostic scopes, though!
deadheadno1
Post by deadheadno1 »
Sigh......., I remember when anything built after 1948 I considered a "late" model. What happened?
