Unibody taillight panel
62bigwindow
Post by 62bigwindow »
Is there a difference in the long and short bed taillight panels/bed extensions on a unibody? Mine are pretty beat up and was going to look at some in a local junkyard.
jamesdfo
Re: Unibody taillight panel
Post by jamesdfo »
Yes, the SWB & LWB are different, but in a pinch, a handy guy with some fab skills can make one work on the other, but there is some sweat equity required.
There is a thread on here where this was discussed, and the OP put up pics of where he had to make changes (where the body line from box panels flows into the taillight panel, and also where the hinge mounts.)
I'll see if I can locate that thread, if I do, I'll post the link;)
James
jamesdfo
Post by jamesdfo »
Here it is! And my memory apparently isn't that good, because the changes required are at the very top and where the hinge mounts......
viewtopic.php?f=32&t=36958
HTH
James
Might want to note Foodstick's comments on that post!
62bigwindow
Thanks! That helps alot.
64 f100
Post by 64 f100 »
There are a pair of NOS ones on Evilbay as we discuss this.
62bigwindow
Yes. I seen them. That why I asked. If I knew for sure they are for a short bed I'd grab them.
