I knew it had been a while but dam- I am getting old!
Anyhow,The past couple years I have not been able to drive my old 66 very much.My left hip and back pain are greatly intensified if I drive it much.
I left it totally stock back in 01 when I went thru it. 300 inline 6, 3 speed on tree, 2 piece driveshaft and so forth.
I have gathered over time a power steering pump and box. Not sure which 1 as it has been a few years since I even saw it.I also have all the stuff to convert it to manual disc brakes on the front. Ibeams and all from a 73.
The brakes I can do,except,I might as well put a booster on there if I can.I have helped do a couple disc brake conversions and although the king pins are a pain, it can be done.
What I will be looking into is what automatic transmission can I put in the truck without carving it up?
I remember helping put in a 390 with c6 and a cross member had to be removed to fit everything in. A bit more trouble than i am able to do.
Would a C4 fit the 300 6 without alot of carving? I bought a 04 Hemi dodge last winter and use it for heavy towing and traveling. I just can't drive the 66 like I want to and I either need to sell it or make it so I can drive it.
I hate the idea of for all practical purpose street rodding the truck but I can't use it much as it is.
So you may see me lurking here trying to get educated
