1965 1966 F-250 OEM 361?
I have not personally seen or heard of a factory 2 or 4 barrel 361 but several part stores show this option for 3/4 ton pickups. Has anyone owned or seen a factory Slick with a factory 361?
Re: 1965 1966 F-250 OEM 361?
My 1966 Ford/Mercury Truck Factory Shop manual does list a 361, under engine code E, descr is 8 cyl. 361 CID, (2V)
BUT, when you go to Group 8, ENGINES, Part 8-6, it lists 330 MD V-8 and 330, 361 and 391 HD V-8 Engines
From this, I would expect that this is an FT engine, and was only available in trucks heavier than F-350's ?? (ie: F-500 & up)
Guesswork only, but an educated guess:):)
And just to verify....see post #6 in both threads below
https://www.ford-trucks.com/forums/1510 ... ne-id.html
https://www.ford-trucks.com/forums/1004 ... arted.html
and see posts #9, 10 & 11in this thread
and some good info on ID of FT vs FE in this thread
https://www.ford-trucks.com/forums/1039 ... n-vin.html
James
James
Yep, only ones I have ever encountered were U-haul trucks, and it seems they may have been the only ones to get them!
It must be a rental option. My pickup is a basic 352 2v 65 3/4 ton truck but had a governor under the carb. I couple here say they remember my set up from the U-Haul pickup rentals. Maybe the 361 pickups came from the same assembly line as the W code Mustangs.
Thanks for the links
You think that the 361 was a planed rental pickup engine that didn't happen and was replaced/scrapped with a simple governor under the 352 carb?chris401 wrote:It must be a rental option. My pickup is a basic 352 2v 65 3/4 ton truck but had a governor under the carb. I couple here say they remember my set up from the U-Haul pickup rentals. Maybe the 361 pickups came from the same assembly line as the W code Mustangs.
Nope
"Didn't happen"! It DID happen, I have worked on a handful, and owned several in the short term.
361 in a 3/4 ton?Toyz wrote:"Didn't happen"! It DID happen, I have worked on a handful, and owned several in the short term.
Looks like you misread the 3/4 ton part. The W code Mustang was a joke.Toyz wrote:"Didn't happen"! It DID happen, I have worked on a handful, and owned several in the short term.
The links provided by the first response spoke of the small (352/360) crank snout 330 MD like what I had but you told me it didn't exhist. That is just one example. Seems you make it a point argue because it is or is not in the books. Being only 43 some of you have a life time of experience over me and should have an open mind about things.
I was joking about it. Many arguments about it on the internet but no one has any living proof.chris401 wrote:The W code Mustang was a joke.Toyz wrote:"Didn't happen"! It DID happen, I have worked on a handful, and owned several in the short term.
