no spark - very hot coil
redstone65
Post by redstone65 »
I'm hoping someone can give me a push in the right direction. My truck died on me on the way to work Monday and my wife towed me home with the F-150 (she's awesome like that). It sputtered a few times and then just died.
Bottom line now is that I have no spark on the plugs. I replaced the coil and the condenser since they are cheap parts and I haven't changed them since I've had it. That didn't work. The points are opening and closing and the rotor button and distributor cap are in good shape. One thing I'm noticing is that when trying to crank it, even just a few times the coil gets too hot to even touch. Is that normal? The voltage regulator gets hot too, just not so extreme.
Anybody have any ideas on where to move to next?
Dave
Re: no spark - very hot coil
Coil shouldn't get hot in a short amount of time...
You say if you crank it , the coil wire sparks ?
But when you put the coil wire into the cap ,
The plug wires don't ? ......
I've never heard of anything like that... even a cracked cap
Will fire some of the plugs
My guess is a ground type problem
Maybe you didn't get the points in correctly ?
Are you running a direct or resistor voltage to coil ?
Check your primary wires from coil to points and to condenser. One or the other is continously grounding out, or the points themselves are grounding continuously.
Blackwaterforge
Post by Blackwaterforge »
X2
redstone65
slick4x4 wrote:You say if you crank it , the coil wire sparks ?
Sorry for the confusion. I'm guessing by "coil wire" you mean the big, spark plug looking wire coming out of the center of the dist. cap going to the coil? If so, then no I haven't checked for spark on that wire. I'm not sure how to check for spark on it since the metal connections are down inside the dist cap and the coil. Any suggestions on how to test?
For the plugs I just pulled the plug from #1 and held the threads against some bare metal on the engine block and watched for spark in the gap. If there is a more reliable, better way to check I'm game.
Dave
You can check the spark from the coil by pulling it out of the cap
& just holding it close (less than 1/2 inch ) from a ground
Will spark just like a plug wire
If you have no spark at all ... you definitly have a ground problem
charliemccraney
Post by charliemccraney »
You want a tool like this, https://www.ebay.com/itm/New-Adjustable ... SwVFlT7tIb. Makes it easier, and without the risk of shocking yourself.
Start simple, if coil is getting abnormally hot, something is grounding the primary circuit. Verify that points are in closed position (off cam lobe). Put a piece of paper between points contacts, turn key on, snatch paper out. There should be an obvious spark. If not, turn key off, remove primary wire from points, turn key on and touch that wire momentarily to ground. No spark, replace that wire.
Disclaimer: coil may have been damaged by continuous grounding/ overheating. If grounding is at points or condenser wire, check points for pitting since they also may have been damaged.
That continuous grounding will also damage the resistor wire, you may reach the point where you have diagnosed and repaired original problem, but have engine die immediately after releasing key from start position. If this proves the case, replace your pink, heavily insulated resistor wire under dash. It is easily obtained at a full service auto parts store.
Gravemetal
Post by Gravemetal »
A bad condenser will give you a constant ground. From what I have read on the net the new condensers are crap out of the box
Yep
redstone65
Gravemetal wrote:A bad condenser will give you a constant ground. From what I have read on the net the new condensers are crap out of the box
That might be the case. I actually got it running tonight, with caveats:
1. Did the paper test per Toyz, but paper wouldn't pull out because the points were pitted.
2. Couldn't get a spark at the coil wire or by fiddling with the points.
3. I pulled out the wire (it was sketchy looking) going from negative on the coil to the points and just ran a fresh wire with some crimped ring ends.
4. Then when I fiddled with the points, one time i noticed a very weak crackle.
5. Checked the voltage at the points and got 6.5 volts.
6. Replaced the points. They were pitted pretty badly.
7. Put everything back together and it fired right up.
8. I had already replaced the coil and condenser, so I figured problem solved - bad points and maybe/probably bad wire.
9. Then I saw that I had forgotten to put the screw back in that holds the condenser to the plate in the distributor.
10. I pulled the cap and rotor button and screwed the condenser down to the plate.
11. Replaced rotor and cap and now it wouldn't crank again. :roll:
12. Took cap and rotor back off and unscrewed condenser from plate.
13. Put cap and rotor back on and it fired up again.
14. I then drove it around the block and came back home and let it idle.
15. It was idling wierd. Sort of a drifting idle. It actually died once and I re-cranked it.
So, it's running, but I don't know why screwing the condenser down made it flake out again. I still have the old condenser and I'm thinking of putting it back in. I don't know if it was bad. I just replaced it by protocol because it was a cheap part. I also never replaced the ballast resistor that's attached to the wire going to positive on the coil. Not sure if that's necessary.
And, I'm not sure what the rough idling is all about. I haven't gapped the points yet, so I'm guessing that could have something to do with running rough.
Any thoughts?
And, thanks so much for the advice guys. It's really helping.
Dave
First thought would be the bad condenser; sounds like it may have an internal short to ground when tightened. I can walk you thru extensive condenser testing , but you are probably better served by re-installing the old one.
Idling/dying may well be the bad condenser coupled with in-sufficient dwell due to point gap. The only other things I noted from your description was in reference to the ballast resistor. I'm a little biased, but I don't like ballast resistors! They tend to vary output due to temperature more so than the original resistor wire. 6.5 volts is fine, but approaching the 6.6 maximum recommendation. If your starting bypass wire from starter relay is not tied in AFTER the ballast resistor; you are likely getting very minimal voltage while cranking, potentially affecting starting.
So, if you are happy with the points system, just carry a spare set of points and condenser.I very much like the Pertronix electronic conversion, it's very dependable when installed correctly, easily removed and points re-installed in case of a problem or need for diagnosis, and, did I mention, cheap!
Ok, off my soapbox of personal likes and dislikes; it sounds like you are well on your way to a solution; I recommend setting the dwell after initial point gap setting; it is the critical setting; then finish off by checking and setting initial timing plus checking advance. Easiest way to determine a poor condenser, (or points) is by those pitted points, so might check them occasionally.
Good luck!
redstone65
Thanks for the Pertronix recommendation. I have wanted to do the conversion to electronic, but didn't know how well it worked. It's nice to have a solid recommendation. I want it all to remain looking stock as much as possible. I'm going to go ahead with the conversion but figuring this out has now become an obsession. :-)
Toyz wrote:6.5 volts is fine, but approaching the 6.6 maximum recommendation.
Ok, I put the old condenser back in and removed "ballast resistor" (which I now don't think is a resistor at all - looks like a condenser). I then checked voltage at the coil wire again and got 6.69 with key in on position (not running). I put the old coil back on and got 6.4 with key in on position (not running). Both old and new coils seem to output about 9.5 volts while idling.
I gapped the points to .17 at the high point of the cam lobe.
The good thing now is that the coil is no longer getting hot while sitting with the key on, but the idle is still rough and it's dying. Gets worse and dies more when it heats up. In fact, when I fired it up this morning it idled pretty good for about 2-3 minutes and then the rough idle kicked in and it started dying. Not sure what that means.
I haven't set dwell angle yet. I'll do that next.
What I was calling a ballast resistor (it was just hanging off the positive wire going to (+) on the coil):
Couple of questions out of curiosity:
Can anyone identify which distributor this is? The ID plate is almost unreadable.
Image Image
Also, does this wire that I used to rewire the distributor to coil (-) seem big enough?
Dave
Mr. Jones
Post by Mr. Jones »
Installed petronix in my 66F-350,300 c.u.i....best thing I've done...it's running on first spark before I can let go of key,smooth idle and better power.....
Yep, that condenser is for radio suspression, Unfortunately the rated range makes it unsuitable for substitution for the distributor condenser, so just toss it!
Blue wire looks to be adequate. Since I am counting only seven secondary wires, let's go ahead and open that point gap to about .025", then set the dwell somewhere in the 37/42 degree range.
I can't positively identify the distributor, look at the plate where the condenser/ points mount; if it has small advance springs, you are in luck. More likely, though, you have the infamous "Loafomatic", with advance controlled solely by a port on the matched carburetor.
The Pertronix won't work miracles; it is, however more tolerant of distributor looseness than a conventional system, and as Dan said, the improvement is often immediately noticeable.
Again, good luck, looks like you are progressing well!
redstone65
Man I can't thank you enough Paul. This is so helpful.
This is the inside of the distributor. It definitely has little springs:
Does that help ID it? Just trying to figure out which one it is so I'll know which Pertronix unit to order.
Dave
redstone65
Ok, I was able to clean the ID plate enough to ID it as some version of the C5TF- model. It also has "5F A" stamped on the left side of the plate.
I see a few different versions of the C5TF listed:
C5TF-12127J
C5TF-12127K
C5TF-12127L
C5TF-12127M
C5TF-12127V
Does anyone know if there is significant difference between these different models.
Dave
redstone65
Plugs gap: .032
Points gap: .025
Dwell: 40
My dad and I worked on this all day and ended up running an entire new ignition circuit with a new resistance wire (Motorcraft# DY-37) from the key all the way through to the starter solenoid and coil. Still same rough idling and dying issue. I think the verdict at this point is that the distributor is shot. There is about a 1/2" of play in the distributor shaft if you wiggle the rotor button.
I'm ordering a new distributor tomorrow and I'll post back with results once installed.
Dave
Half an inch ?
That seems very excessive
