The axle shafts I am finding are not machined for the cones. Looking for a set of 30 splines that fit tight enough not to move around and leak on my stock hubs with the studs.
16 To 30 Spline Conversion, Locking Cones
Re: 16 To 30 Spline Conversion, Locking Cones
Has anyone here converted there 16 spline 60 to aftermarket 30 spline and had problems with the new axle shafts leaking around the hub?chris401 wrote:The axle shafts I am finding are not machined for the cones. Looking for a set of 30 splines that fit tight enough not to move around and leak on my stock hubs with the studs.
