Early this afternoon, when I got back to my across town & back roadtrip, I went to the shed to see if the rag joint was still on the column we saved out of a '66 Custom Cab we eviscerated a year or more back, of course, it wasn't there
So I texted John to let him know.......and a short while ago, I got a text back.......
"Just finished. Got universal Borgeson Rag Joint, and it worked fine. Ground the heads off two bolts & pounded them out of the spline end of the joint & bolted the new Borgeson Rag in. The Borgeson Part No. is 000941. Called Replacement Rubber Rag Joint Kit. Fit like it belonged."
So, there you go, an economical solution that should be made from quality materials, unlike some of the off-shore repops
http://www.borgeson.com/xcart/product.p ... 453&page=1
Replacement rubber rag joint disc with hardware. Fits many Chevy , Dodge, Ford and Jeep applications requiring a 3.25" diameter rag joint disc.
James
