Reading the book, it says to torque them down depending on the bolt sizes. IT listed a few possible sizes of bolts but what I ended up getting we’re 7/16-14 x4 (have 5’s as well if I needed them).
When tightening the bushing, it is squishing the bottom one almost flat. Is this right? When from a 1” thick disk to a donut look.
I haven’t even reached the torque spec is was calling for. The top disk is still thick.
In the old set up it had these thing sleeves that went between the rubber disk and stopped the bushing from crushing I think. Been years since I’ve taken it apart and those old ones ended up getting cut out due to seized nut/bolt.
It is bolt thru fat washer, bell housing, disk, crossmember, disk, washer, lock washer, nut.
That right?
I’ll try to get photos to show.
