Look at my electric panel
See what I see?
I didn’t do it!
I opened the panel today to fin a place I can run so,e wore to my air compressor. I haven’t done it yet, but saw that and was like WTFO!
Pre ious owner was a nice enough guy but sort of a village idiot.
oldsmiley
Re: Look at my electric panel
Post by oldsmiley »
WOW.....good thing you caught it before you smelled smoke.
Been there myself.
FarmMotorSports
Post by FarmMotorSports »
That damage is on the non feed end of ONE buss bar. I would have NO problem whatsoever using that panel, IF that is the only damage.
Make a note to your self not to use the top two breaker slots in your panel. And you still have a lots of open slots for breakers...
:2cents:
61 F250 Unibody
& 4WD
Yea.... I was trying to see why you were concerned
Top has some arcing marks .... I’m no certified electrician....
But the rest looks fine
Previous owner a bit of a village idiot.
FarmMotorSports
That is assuming that all that blue electrical tape is for identification of wires, not to cover up degraded, brittle falling off, insulation on the wiring itself... it's hard to tell without checking the box in person.
I've seen much worse, inspect, research, then repair only what you need to. It is the joys of home ownership, don't ask me how I have learned that.... :roll:
61 F250 Unibody
& 4WD
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
April that does remind me of a 1972 we brought in and every wire in the truck was RED,, What a mess trying to sort out
12649
Lowell
Post by Lowell »
I was also concerned with the blue tape. has the insulation been melted from an overload?
6166 Junkyard Dog
if you look closely at the blue tape you will see a black wire taped and a red wire comes out the other end
12649
I think the blue tape was put on there as a marker
Not for a bandage
All the blue goes to 220 breakers
castruck_1964
Post by castruck_1964 »
those could also be the 120 split recptacles in the kitchen
Slicks rule
dd/ 19 F150,97 Tbird
62 swb bbw uni next project
460 C6
Ken
Blue tape is s posed to be good for keeping smoke in... isn't it ? :shock:
Lol right! I still need to purchase materials for the electric portion of my compressor,
Oh and I may get some copper pipe and do a nice air drop set up around... making a few drain points.
