headlight adjusters source
ratrapp
Post by ratrapp »
does anybody know of aftermarket headlight adjusters that you can buy from say autozone,advance auto, fisher or napa?i forgot to order some from lmc and really don't want to make another order just for these.plus would like to get them alittle quicker.none of the catalogs in the stores go back far enough to list these.getting ever closer to getting it road worthy.it is a 66 but I don't know if it matters or not.
tomrooster
Re: headlight adjusters source
Post by tomrooster »
I broke a couple and make some temporary ones out of a small bolt, I think 1/4" and 2 or 3 nuts. A pain to adjust but it got me on the road again. They might be still there now that I think about it. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
jamesdfo
Post by jamesdfo »
Find an autobody jobber near you, hopefully, they are a dealer for Auveco, or Spaenaur (google them), or both. If you have a sample, take it along. Between the two Co's (and there may be others), they should be able to come up with something that will work for you.
https://www.auveco.com/
https://www.auveco.com/headlamps
https://spaenaur.com/
see pg H33
https://spaenaur.com/wp-content/uploads ... 30-H34.pdf
James
ratrapp
Post by ratrapp »
I got some but now to find a good grille.the grille is so mangled where the headlight buckets sit is the problem.i ve got a lead on a decent grille and should know by today or tomorrow if can get it.
