Ford 303 3 speed tranny output shaft seal
Webfoot
Post by Webfoot »
Xx
Re: Ford 303 3 speed tranny output shaft seal
Might have to pull it to get dimensions
Any bearing store should be able to get a seal to fit
If the shaft has a groove ... polish it up with emery cloth
Even if you can’t polish it away, just smoothing it out & a new seal
Should work good for a long time
Webfoot
Post by Webfoot »
Xx
jamesdfo
Post by jamesdfo »
have a look @ this..........
https://www.ford-trucks.com/forums/1518 ... -seal.html
and, if the output bushing happens to be showing wear......
https://www.ford-trucks.com/forums/1520 ... shaft.html
Lowell
Post by Lowell »
if your tranny has a slip yoke like mine, its a good idea to replace the bushing while you are it, or the new seal may not last long.
Webfoot
Post by Webfoot »
Xx
