Just wondered what everyone else is running. I've got an autolite 1100/Ford carb on a couple of my straight 6s and I keep having to replace the accelerator pump diaphragm every year. Does someone offer an ethanol resistant pump diaphragm that will last a little longer (the blue/green one)?.... Neoprene or viton I think is the word I'm looking for.? I replaced my GM's quadrajet accel.pump and needle and it's been working great for 2 years now. Would like to do the same with the autolite if someone knows who carries them.
Edit: I'm thinking a Holley 135-10 diaphragm is VERY similar and should work with a slight modification or maybe bolt right on.
Autolite 1100 constant maintenance
-'61 F100 short box flareside (classic street rod) 223, 4spd
-'62 F100 long box unibody (murdered out) 460, C6
-'66 F100 long box flareside (original) 240, 4spd
-'64 F100 long box styleside (pro-street) 307 GM, 700R4
-'64 F100 long box styleside (daily driver) 223, 3spd
-'65 F100 long box styleside (original) 240, 4spd
-'66 M100 long box styleside (sold) 240, 4spd
-'64 F250 long wrongbox styleside (sold) 292, 4spd
- ThinLizzy13
Re: Autolite 1100 constant maintenance
Is the diaphragm itself getting a hole in it or does it just start leaking? Sometimes the metal cover can get slightly warped from over tightening which will allow it to leak pre maturely.
FWIW I ran a rebuild kit from Mike’s Carburetors and had zero issues with leaking or deterioration. I think they sell individual parts on their website.
- Gravemetal
If you are googling stuff the word is vitron. I have used them in hydraulic situations
The diaphragm hardens and cracks. Spider web cracking across the whole thing. I've been using a Hygrade pump that comes in the kit from a local parts store, I'll have to try the one you suggested from online. I might be a little paranoid but I really don't like random fuel leaks in the engine bay since a cracked fitting almost burned my 57 Chevy to the ground when it sprayed gas onto the coil last year.ThinLizzy13 wrote:Is the diaphragm itself getting a hole in it or does it just start leaking? Sometimes the metal cover can get slightly warped from over tightening which will allow it to leak pre maturely.
Thanks, couldn't remember but that's probably what I got for the Q-jet.Gravemetal wrote:If you are googling stuff the word is vitron. I have used them in hydraulic situations
