16 inch wheel replacement
busboy
Post by busboy »
I hesitate to ask because I know I’ve seen the answer here before but I can’t find it. What Ford van wheels will replace the 2 piece 16 inch wheels on my 65 F -250?
And will the 69 F-250 hubcaps fit the van wheels?
FarmMotorSports
Re: 16 inch wheel replacement
Post by FarmMotorSports »
1976 thru 200? Model years, E250, E350, E450 should have 16" wheels with the 8 on 6.5 pattern.
Some of the early years may have 16.5" wheels...
Yes your 3/4 ton hubcaps will fit...
Note: supplying manufacturers may have changed over that large of a span of time.
So mixing and matching years may show slight style/stamping changes...
:2cents:
Would your current wheels be of the inney or outie variety?
Actually in bad shape, or just can't find a tire place that isn't terrified of a two piece rim.
61 F250 Unibody
& 4WD
busboy
Post by busboy »
They are the original two piece 16 inch. I can't find the innie bottleap hubcaps for them that are the original type. I have one hubcap. I can change tires on them but tubeless radials are so much easier to just put a plug in.
FarmMotorSports
If you have the storage space for them, Don't trash the original wheels, there is a small but fervent market for them.
I have bought my inney hubcaps one at a time reasonably on eBay....
61 F250 Unibody
& 4WD
