I have an extra Dana 61.
3.07 ratio, eight lug on 6.5 pattern.
These are not quite a bolt in for slicks. They may require installing new spring perches in a narrower pattern for slicks..
May come real close to being a bolt in on a bump side or newer, due to the wider frame.
I also am offering up my Disk brake straight axle, complete if there is any interest.
This combo might work well for someone looking to rid of the 6 lug wheels and drums on a 1ton...
Not a bad combo to work with a granny 4spd and a V8, or a big block truck....
Should make it interstate worthy..
I'm converting to 4WD, so these need to go...
Pm me for details and we will make a deal.
Dana 61 3.07 ratio rear
- FarmMotorSports
61 F250 Unibody
& 4WD
& 4WD
- FarmMotorSports
