I read somewhere a different heatercore would fit the Slick60's pickups. I have a 1965 2wd F-250 with the slopped floor, not the step. Would like to get one likely to be in stock on a Sunday.
Thank's
EDIT: Blower motor is in the cab.
What Year Of Heater Core Is Close To A Slick?
Re: What Year Of Heater Core Is Close To A Slick?
Thru 72 without factory air is the same except the tubes are longer. If you have a radiator shop the can recore yours, I used a core from a later LTD that was within 1/4 inch
and put my end with outlets on it and put it in Skyliner.
Johnny
Johnny
Thank's, I'll look into it Monday. My Spectra core was only in for 2 or so years till it started leaking. Of course this happens just before we leave for a 9 hour trip. Seems someone had one from a latter year that was close enough to work in a jam.
may be to late ,but a 66-77 bronco heater core should work
66 f100 4x4 ,64 f100 4x4 ,65 f100 2wd, 76 bronco, 74 bronco, 68 bronco, 69 mustang mach 1,68 torino gt,42 ford gpw
I'll look at that option when I get back. Thank'sgreentruck wrote:may be to late ,but a 66-77 bronco heater core should work
