great thread-block couldn't take the 3000hp
Phil
Post by Phil »
Johnny Canuck
Post by Johnny Canuck »
NASTY! :shock:
most definitely cooked that engine.
Jarrod
Post by Jarrod »
definatly no bueno. 3000 hp is a lot of power. I have never seen a block do that. I have seen hi power FE motors have the botom of them fall out but that is just straight nasty
Cheers,
Jarrod
Phil
Post by Phil »
Kinda common when 302's get over compressioned, never seen that in a BBF
blackagatha
Post by blackagatha »
holy shit!
What is this about hi-powered FE's? I feel that I need to know. Not that mine is anything special, but it may be some day...
Slick Fan
Post by Slick Fan »
I like that first pic with the dual hair dryers! :shock:
Sorta looks like what some guy's 347 stroker small block looked like. I found these on some 'Stang site a while back, I think nitrous was involved...
FORDBOYpete
Post by FORDBOYpete »
Phil,
I studied that on the 460 site. I won't fault C&C's block it was caged roller cam bearings that caused the catastrophic destruction, IMHO. :shock:
When the rear most cam bearing boss was forced to suddenly eat that extra 3/16" or 1/4" of jumped roller metal. It was like hitting the block with a huge cold chisel at the 3:00 o'clock position, as shown in Pic 4 of the renfro block. shrug.gif
The out of round is evident where the "jamb up" took place. Even the oil galley plugs were disturbed by the shock of such an expansional impact. At least that's how I read that path of destruction. Never the less he has my condolences for sure for suffering such a apocalyptic engine failure.
But as we all know, I've been wrong B4 doncha see? :hm:
Now the evidence in SF's Pic's is something I've seen in SB's a few times. It's one reason nobody runs N/meth thru SB's. Also a reason I put my faith if 385's. Of course my lousy 475-500 est-HP doesn't compare to what that huffer makes. . . . whistle.gif
:peepwall: FBp Bolt.gif
Change is the Only Constant
blackagatha
I never considered it before, but even without the roller cage getting stuck in the cam hole (might it have done that post-failure?), there is not really that much structure holding an engine together on the lateral side of things.
with 3000hp, I imagine even the slightest irregular thump or ping could have pushed the iron past its limits. Afterall, Iron is strong as hell under compression, but NOT (extremely) strong when being pulled apart.-under "normal" conditions, it does just fine, but at the extreme limits, it gets iffy.
Phil
Post by Phil »
FE failure
Friend of a buddy.
blackagatha
what did the FE do to deserve that? whaat happened to it? do they know? what sort of setup was it running?
All I know is that I really DONT wish to replicate that.
FORDBOYpete
:oops: Fe pushed his cast crankshaft too far by the looks of things. . . . :roll:
427 SOHC & DOHC's lasted much longer when we used billets instead of the cast cranks. I broke a PI Based 390 FE along the skirt of the so called "Y" Block casting and it puked a couple of main journals too. My crank came out the side but it landed on my "centerlink" keeping steering to a minimun in the Falcon it was in. . . . HEll....o? oops.gif I will add since that period in history, Rogue River & Windsor Plants perfected Nodular Casting processes & improved durability factors of castings, at least FoMoCo castings anyway. All Windsor Engines from 144 CID I-6 thru 5.7/ 351W V8's are nodular, as are cranks in 385 series engines. There's probably more FoMoCo engines with Nodular cast parts, but I don't care about them.
I've grown up some since my "handgrenade" says of the late 60's & early 70's. I still may be only 19, but I have a hell of a lot more years experience at being 19. So I tend not to twist my engines beyond reality. Read reality as harmonic flexing from too many RPM's, aka beyond limits of the reality of physics & metallurgy. Ergo the gold at the End = MORE than a pile of broken parts + my heart in my throat from trying to stay in control & get stopped,{ iff'n y'all catch my drift}. Now Hubert Platt could explode an FE Engine, I mean like Hirhoshima Style. . . . shrug.gif
I guess the concept of High Torque @ Lo RPM finally Sunk In after driving a couple formula, class 8, Diesels & discovering I could haul the frieght as well or better with that config than I did if I turned the governor & fuel pumps up. DUuuh? Lasts longer runs cheaper pulls as well or better & won't break as much/ often. :hm:
Wow! :shock: Engine Salvation & economy! That's a concept worth keeping. :roll:
So far I haven't broken a crank in a 385 engine. Actually I haven't broken a 385 engine for that matter, I wore a couple out tho'.
:peepwall: scared.gif FBp Bolt.gif
Jarrod
Post by Jarrod »
Pete,
I know about the 427 SOHC but I have never seen DOHC head. Was that some special Holman Moody race only if you have to ask you can't afford it kind of deal?
Cheers,
Jarrod
BigTim
Post by BigTim »
Jarrod wrote:Pete,
Ditto on the DOHC?
FORDBOYpete
Smokey Yunick did them, remember "the Best Damn Garage In Town right here in Dayt Bch? It's when 63-67Galaxies reigned with likes o' David Pearson, Fred Lorenzen, Ned Jarret & all those other Crazy Ol' Men who made NASCAR What It Used To Be back in the day. :wink:
It was a low hemi configuration, twin cam, close to new modular DOHC's in principle but FE's are overpowered & over performed capabilities of "Y" style FE Blocks. Cast cranks even with Girdles & 4th or cross bolted mains would fail. They were known as "side oiler" blocks too. the internal Galley set up didn't oil the cam drives or followers so they used external plumbing to getterdun.
I do not know for sure but do you guys know of, or ever hear of Moser Heads? The old cover car for Car Craft Mag'had a 32 Highboy with a 383 CID SB Brand X that has Moser heads they are DOHC Hemi. I think they were experimenting with Smokey Y' here back then. 8)
Smokey had nearly Free access to the track at "DIS" & we'd sneak in to watch them "play" with their ideas. IF a DOHC 7 Liter ran a SuperBird 426 Hemi in these so called "practice & testing sessions & didn't handgrenade it could eat it that MoPaR for lunch. You "ain't heard a Stock car race until you hear a couple of Superbirds & 427 FoMoCo's go at it. It's sorta like experiencing a sony boom on the deck of a carrier as a Tomcat goes by at a Mach II rate. :shock: :shock: :shock:
The sound of pounding Big Blocks has been replaced by Ground shaking Lift Offs of frequent NASA Launches, they are impressive, but Big Blocks dukin' it out @ 200mph on a 2.5 mi tri oval is an epiphany for me. :shock:
Now it's a $100 each for the cheap seats and very little "Playin' (testing) goes on. Doncha love the rules it takes tomake the BIG BUCKS?
FBp 8)
FORDBOYpete
:oops: FWIW, I just spent hrs trying to find anything on DOHC 427s that "GM Mechanic" & his buddy Ralph Moody built, I spoke about above. :shock: :hm:
Smokey was messing with FE's soon after he & Fireball Roberts parted ways. In late 63 Moody brought a "Body In White" Galaxie, 2Dr, Sport H/T, down from Charlotte ( the Hornet's nest) that was the test bed car for quite a few years. Yunick also built a nasty 385 series, 429 CID hemi that was featured in a 73 edition of Hot Rod Mag by Peterson Pub. You can google that up. Most people don't believe Smokey touched anything but GM's. Not true, he built several nasty 302W based engines too. He was up for anything that he thought would be fun. . .
There were 6 or 7, 427, FE's, & a couple pallets of FE parts all sold after Smokey passed away in 2001. They were the last of the lot. You always hear stories and it was said all that "rare FoMoCo" stuff brought around $1M to Smokey's wife. It was not on his "listed Inventory" either.
I know for a fact the shop & the warehouse were both empty when they were sold & torn down to make way for condos a few years back. I was sure there was something about those engines I could cite, but I will be damned if I can find any of it now. . . .
My Probably oldest friend, and a certifiable Indianhead "Pontiac Freaque" with a trophy winning '68- 400x400 "Air Conditioned" Firebird bought the Condo Smokey & his wife lived in from Mrs Yunick a few years ago as a investiment. He still owns it as a rental in fact. He was "Tin Indian" ate up and I was enchanted by Henry's things. . . . Man this is ancient stuff. I will admit proudly I did build a few nasty "Tin Indian Engines" a 421, and a few 400's and a really nasty 455 Superduty Ram Air IV style & all that, for a few friends, back in the day.
We used to watch those crazy bas***ds race North up the beach from the lighthouse at the inlet, then south down what's now A1A back to the inlet and the light house. Both turns were while crossing over dunes the rest of it was laser straight. The EPA and the DEP wouls have heart failure today if that ever happened, All those ravaged dunes & tore up Sea Turtle eggs. . . . . wow I can see the tree huggers, no scratch that, make it Sea Oats Huggers now.
Anyhow, the tourists would hangout at the turns but we locals sat on the paved straight aways, that's where the racin' was going on IMHO. Guys running flat out, 3 wide, on a 2 lane trying to pass each other for a mile and a half, before drifting thru the dunes again . . . . It didn't get any better than that, and it was free to watch.
oops.gif I'm really very disappointed I can't find any of that radical stuff from the past to refer to . . . :roll:
blackagatha
wow that sounds freakin awesome. dammit I wish I could still experience that shit in 2007. haha.
I WOLUD enjoy creating a beast that could replicate that sort of insane power. SOMEDAY, I Might have the cash to do it. It's doubtful though. I will probably have to rip something else off in order to fulfill my dreams... haha
