Garbz
64 f100
Garbz
Post by 64 f100 »
Sent you an E-mail with the address I have for you, but came back saying not deliverable. Wanted you to know, that when I took the heads of the engine with good crank things didn't look good. Took out one piston, checked ring end gap. Never saw a ring with 80 thousandths end gap before. Ruined the cylinders so it has to be overbored. Valve guides are shot also. Good thing I got the good crank, cause that's all I got with this engine. Glad I din't just put it in, I would have been slightly disturbed.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
Garbz
Post by Garbz »
d.garber@bognetinc.com
that ones still good for a week or too
garbz-@hotmail.com is the alternate one
Bummer.... 80 on the rings :( .. what was the taper? whith that much it should be huge. Might not clan up at 60 over.
Garbz
ELpolacko
Post by ELpolacko »
or you can use this one : Garbz@industrialchassisinc.com
64 f100
Post by 64 f100 »
Whoever the dumb bass was ran it for to long. Even the top ring had a ridge on it. Taper was 5 thousandths at the top. Your right, it may not clean up at 60 over, although it would probably work OK, unless it has a bad wear pattern. At a guess, I'm thinking the oil wasn't changed nearly often enough. Valve guide slop was really bad to. Leaves me high and dry, in a couple of respects. More money out, and still have to do another overhaul. Y blocks are a pain, and expensive to work on. Even cutting all the corners I can, I will be lucky if I get by at 800 each. Having to bore one with pistons and rings it's about 3 bills add another bill for gaskets, and another 100 for bearings. Without the the heads it's 500. I'm getting the ones I spent so much money on before redone, for about 300, and those already have hardened seats. Hopefully, I've got a decent set of stock heads, that don't need anything but a touchup. Otherwise, I've bought one new set of lifters, two new rocker assemblies ( big bucks there), and I'm thinking on a bigger cam for the green truck to go with the four barrel and big valve heads. This is one nasty can of worms, I've gotten myself into. Forgot to add, I need a new clutch in the green truck also.
1961 F350
1991 Capri
2011 F250
2004 Lexus
