Lincoln C6 Trasmissions
akfordman
Post by akfordman »
Hi Guys, I've got 71 Lincoln 460/C6in my 65. The transmission mount on end of the tailshaft are shot. Have look allover Anchorage cann't find new ones. Went thur the local salage yards,nohelp. Anybody know were I could order new I say THANK YOU. 8)
reeses66ford
Post by reeses66ford »
hi i work at a parts store i will look and do some calling today for you.
reese
Hawkrod
Post by Hawkrod »
Start crying now! I needed a set a couple of years ago and found out they are no longer serviced BY ANYONE! There are two fixes, one is to find a tailshaft housing from a heavy duty Ford car that has the long transmission (they are rare) as they use the same length housing but use a normal mount. Unfortunately 99 percent of the cars you find will have the same housing you have so keep an eye open in the future until you do find one. And the second option and what I did was make my own mounts. I simply made a bracket that bolted to the two sides where the existing bracket is and used that to mount an aftermarket thin GM urethane mount. Hawkrod
